need help with codes
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Nov 3, 2008
M
MattTheBat83
203
  • Nov 3, 2008
(33 o) egr not working properly and (91 c) o2 sensor reading lean... what does this mean exactly and what should i do about it?
hotcobra03
poteet,tx
Nov 3, 2008
  • Nov 3, 2008
Maybe vacuum hose off or leaking or bad egr
M
MattTheBat83
203
  • Nov 4, 2008
the egr is only 2 years old and all the vacuum lines are hooked up
hotcobra03
poteet,tx
Nov 4, 2008
  • Nov 4, 2008
Check the whole line cracks or kinks.is it a plastic or rubber vacuum hose?and as to your egr,just because its newish doesnt rule it out.
M
MattTheBat83
203
  • Nov 5, 2008
ok so the line that goes to the egr has no vacuum. the rest of my system has vacuum so i pluged a working line to my egr to see if it works and it does. i didn't see any hole or blockage in the egr's vacuum line. what should i do now?
hotcobra03
poteet,tx
Nov 5, 2008
  • Nov 5, 2008
When u applied vac to egr car should stall. Did it?
M
MattTheBat83
203
  • Nov 5, 2008
idk if it stalled but i saw the egr open
hotcobra03
poteet,tx
Nov 5, 2008
  • Nov 5, 2008
Idk how u got ur codes.ok key on eng off code33 or engine running 33 both deal with egr and it gets tricky
M
MattTheBat83
203
  • Nov 5, 2008
it was key on engine off
hotcobra03
poteet,tx
Nov 5, 2008
#10
  • Nov 5, 2008
  • #10
Lets start over.tell me what yr ur car is engine type and how you did ur koeo test and who told u what code stood 4.my book is 3thousand pages thick but 1 page missing koeo codes i did a search and found different description
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
