  • SN95 4.6L Mustang Tech
Need help with procharged 02 gt
  • Thread starter Thread starter procharge
  • Start date Start date Jan 15, 2006
P
procharge
  • Jan 15, 2006
I need help yall!!!!!!!!!! I have an 02 gt with the p-1sc procharger system. i put a bassani x pipe on my car and not long after that it began bogging down at 3500+ rpms... it acts like im not getting enough fuel. i dont know if it is that i need a better fuel pump or what. i heard that some people have problems with the belt slipping on the supercharger but im not sure how to tell if that would be it. also ...it doesnt do it all the time and seems not to do it as often when im riding on a full tank and i do have 373's so i do imagine the pump has a hard time keeping up. Any ideas!?!?!? has anybody had the same problem!?!?!?
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Jan 15, 2006
  • Jan 15, 2006
do you have a boost gauge?? you can tell if the belt is slipping by watching the boost gauge. if you didnt upgrade the fuel pump, i would definetly think about upgrading.
Rick 91GT
Mustang Master
95
99
PA
Jan 15, 2006
  • Jan 15, 2006
Did you upgrade the fuel pump when you installed the blower? I also assume you have the 42# inj and a ATI burned chip?
xseler8
619
Montgomery County,Pa.
Jan 15, 2006
  • Jan 15, 2006
The X pipe should not have a negative effect. I'm using a Cobra pump. Maybe your pump & fuel filter need to be replaced? Get it dyno tuned.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jan 15, 2006
  • Jan 15, 2006
that's not entirely true. adding an X pipe over the stock H can cause the car to go lean when blown if not retuned.
R
RacinJason231
Bakersfield, CA
Jan 15, 2006
  • Jan 15, 2006
I would definatly get it to a shop that can check it out. Stock short blocks are fragile under pressure... Check fuel pressure under load, if FP is good, check the air/fuel ratio, and make some dynopulls with the scan tool hooked up and data logging. The problem with make itself aparent. Might need to rotate the maf housing to correct the airflow over the hot wire. Get it looked at by someone with the means to correctly diagnose it before you burn/melt/or otherwise destroy something. Drive easy!
imblown-ru
247
Roanoke VA
Jan 15, 2006
  • Jan 15, 2006
i just asked the guy that tunes my car if i needed to get retuned after a midpipe/catback and he said catback...probably not, but midpipe yes, it can screw with your air fuel ratios. so i would be very careful and get it hooked up like....yesterday
xseler8
619
Jan 15, 2006
  • Jan 15, 2006
Did anyone change their mid section after a tune and not retune? I did. Tuner didn't seemed concerned.He said HEADERS would call for an adjustment. I'm not challenging anyone here..just curious. Procharge...let us know what the problem was when it gets resolved. Good luck.
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
02 mustang gt crank no start
  • 2v.cjmullis
  • Jan 28, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 30, 2026
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
