NEED HELP
  • Thread starter Thread starter Tayohs 95Gt
  • Start date Start date Aug 30, 2004
T
Tayohs 95Gt
72
Findlay ohio 45840
Aug 30, 2004
  • Aug 30, 2004
My car is leakin alot alot alot of fuel out thru my throtlle body then into my intake.. causing it to go on the ground.. i dont know what would cause this.. and my car will not start.. so does anyone know wha may cause this? thaks
seijirou
2,417
DFW
Aug 30, 2004
  • Aug 30, 2004
Fuel? Out through the throttle body? My initial response would be that this is impossible. Disconnect your negative battery cable, pull off your upper intake. Then go in the car and turn the ignition to on. Come back to the engine bay and touch the negative cable to the battery. This will cause the fuel pump to prime and if you're having a fuel leak this bad you will be able to see where it is coming from. My guess is that you have a fuel leak under your throttle body that might be spraying upwards onto the throttle body. Check to make sure all the bolts are there, not broken, and that the holes for the bolts in the lower intake aren't cracked/broken. Also pull the injectors out and check for good O rings, sometimes the get stuck in the fuel rail when they're pulled out, and when re-installed don't seat properly and leak. Also check the fuel pressure regulator, ect. ect.
T
Tayohs 95Gt
72
Findlay ohio 45840
Aug 30, 2004
  • Aug 30, 2004
like it seems the head maybe flooded? im not forsure but it dumps fuel like no other into the intake. so i dont know.. im just about ready to drop this car and get something else.. thanks for your reply and many more are welcome to put in some input thanks
HISSIN50
34
129
Aug 30, 2004
  • Aug 30, 2004
there is no fuel delivery at the TB. the injectors are in the lower intake. the EGR has coolant lines - could it be coolant?
sorry, i cant imagine how you could 'back flow' fuel up in intake.
good luck.
U
ucanbeatme
107
Williamstown, NJ
Aug 30, 2004
  • Aug 30, 2004
It is impossible to have fuel coming out.. Coolant flows through the EGR spacers.. I think that is what you think is fuel..Check and see what the fuel pressure is..
T
Tayohs 95Gt
72
Findlay ohio 45840
Aug 30, 2004
  • Aug 30, 2004
its very flamable.. and it smells just like fuel.. its not mistaken for anything.. i dont know what is causing this.. but its def not right i just dont know what to do.. my upper intake mani seems to be flooded.. but i donkt know how it is..it shouldnt but im stumped.. MUCH HELP NEEDED thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 31, 2004
  • Aug 31, 2004
Possible bad Fuel Pressure Regulator (FPR) diaphragm leaking fuel through the vacuum supply line. This would put lots of fuel in the intake manifold and leave a strong gasoline smell.
I know the vacuum source for the fuel pressure regulator is not on the throttle body, but it is the only fuel related item in close proxmity to the TB.
Disconnect the FPR vacuum line at both ends and try to blow through it. If you are rewarded with gas spitting out, the diaphragm is bad.
D
Daggar
3,902
  • Aug 31, 2004
JR... You da man!
seijirou
2,417
DFW
Aug 31, 2004
  • Aug 31, 2004
Yeah I went through the FPR thing with him on IM last night. That's not the cause either. The only thing else we could come up with would be injectors staying open constantly, like their getting 12v all the time, but I guess it could be mechanical failure of a few of them. He also said there is nothing else hooked up to the fuel system like a pressure guage or a nitrous system. So I'm running out of ideas. I wish I could see this one for myself actually.
T
Tayohs 95Gt
72
Findlay ohio 45840
Aug 31, 2004
#10
  • Aug 31, 2004
  • #10
im plotting tommoorw to tear apart the upper and lower part of the manis..and checking the injectors.. but if my intake manifold is flooded, isnt it very possible so are my cyclinders? i dunno. may be i should just get another motor? But i dunno if its something electrical rather than mechanical.. leme know what ur imput is thanks
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 31, 2004
#11
  • Aug 31, 2004
  • #11
Have you pulled the codes?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 31, 2004
#12
  • Aug 31, 2004
  • #12
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 31, 2004
#13
  • Aug 31, 2004
  • #13
Fuel pressure OK, the injectors are not firing, OR one or more injectors stuck open
The red wire on each injector is powered up whenever the ignition switch is in the Run position. The computer provides a ground to complete the circuit and fire the injector. The injector must have a ground to squirt fuel on command.
A.) A Noid light available from Autozone, is one way to test the injector wiring. If the light stays on constantly, either the wiring has a short to ground or the computer has failed.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. You’ll need it to do the cylinder balance test
OR
OR
Second method is the cylinder balance test. Warm the car's engine up to normal operating temperature. With the Engine Off, Key OFF, use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 99 or the number of the failing cylinder such as 22 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
The wiring for the injectors may have some bare spots in it causing the injector to computer control wire to ground out. This would cause the injector to remain on anytime the key was in the Run position. Remove the injector wiring connectors from the injector. Note that each injector has one red wire for power and a non red wire (wire some color other than red) for computer controlled ground. With the key off, use an Ohmmeter between the non red wire and ground. You should see more than 100 ohms resistance.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
seijirou
2,417
DFW
Aug 31, 2004
#14
  • Aug 31, 2004
  • #14
Didn't know it used a switched ground, thanks for the info. Now I'm really thinking it's electrical.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
