Need help.
  • Thread starter Thread starter 93FiveO
  • Start date Start date Oct 18, 2006
93FiveO
20
Decatur,AL
Oct 18, 2006
  • Oct 18, 2006
Well today I just noticed that my car misses and it pops when you put it under a load.So what do yall think is is wrong?
Spark plugs?
anyway thanks
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Oct 18, 2006
  • Oct 18, 2006
could be plugs, wires, cap, rotor, coil. it could also be a bad injector that is dumping fuel. could also be timing. what timing are you running?
93FiveO
20
Decatur,AL
Oct 18, 2006
  • Oct 18, 2006
Im running the stock timing and I use shell 89 gas.Im going to take into autotech
and see whats wrong.My dad and I are going this weekend to get new plugs and plug wires.How much whould a better dizzy be? or would it be point less to not put a stock dizzy with a stock coil and that box thing I forgot what its called.
HISSIN50
34
129
Oct 18, 2006
  • Oct 18, 2006
Pull codes. Check that your dizzy doesnt spin by hand (indicating that the hold down came loose).
You can check the plug wires at night for bleeding.
Good luck.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
F
Leak from tail shaft after 2 new seals
  • Fox123
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
JD1964
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
