need help
  • Thread starter Thread starter kylem40
  • Start date Start date Jul 17, 2009
K
kylem40
21
  • Jul 17, 2009
ok so im new to this but ive got a 79 mustang that the motor blew in it so i put a 93 f150 5.0 in it and converted it to carb cuz thats wat it was before but it back fires threw the carb i bot a new distributor a new coil n the carb was new. i had had the timing set to 10 degrees cuz thats wat i was told to put at n had it perfect
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 17, 2009
  • Jul 17, 2009
Non-tuning issue - moved to 5.0 Tech.
Are you sure the timing isn't 180° out of phase?
apollo12
155
port st.lucie fla
Jul 17, 2009
  • Jul 17, 2009
are you @ t.d.c with the rotor facing #1 on the cap?
K
kylem40
21
  • Jul 18, 2009
yah I took out the spark plug n when it push my finger out of the hole I made sure it was tdc then set the timing to 10degrees n the more advanced I go the smoother it runs so Idk
K
kylem40
21
  • Jul 18, 2009
but it always back fires when u get on the throttle I was wondering if it mite have something to do with the carburator to its a holley 600
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 18, 2009
  • Jul 18, 2009
What firing order are you using? The truck may be different than what the 79 was. I know a truck is different that what an HO motor is but Idk what 79 used.
K
kylem40
21
  • Jul 18, 2009
im using the Ho firing order for a Stang I just figured all the Ho motors wud have the same firing order
apollo12
155
port st.lucie fla
Jul 18, 2009
  • Jul 18, 2009
f 150 truck motor isn't an ho motor
K
kylem40
21
  • Jul 18, 2009
it isnt? well crap that mite be a problem i jus thot all 302s were
K
kylem40
21
#10
  • Jul 18, 2009
  • #10
man i thot all 302s that were 82 to 93 where well i need to find the firing order for it then
K
kylem40
21
#11
  • Jul 18, 2009
  • #11
well thanks for telln me that man cuz thats the same firing order as the 79 motor! im guna try it n c what i get
apollo12
155
port st.lucie fla
Jul 18, 2009
#12
  • Jul 18, 2009
  • #12
1994 and eariler 302 1-5-4-2-6-3-7-8 1995 and later 302 1-3-7-2-6-5-4-8
K
kylem40
21
#13
  • Jul 18, 2009
  • #13
im also lookin to put gt ground effects from the 87 to 93 years on my 79 ive got the gt front bumper on it im jus wondering if it wud all fit? i also tore out my dash n put a dash from a 1990 in it n ive gota upgrade everthing on it cuz it used to be a 4cyl where wud be a gud place to get all the suspension n rear end n all that?
K
kylem40
21
#14
  • Jul 18, 2009
  • #14
yah c i was using the second firing order that u posted
K
kylem40
21
#15
  • Jul 18, 2009
  • #15
i jus wana say thanks for all the help cuz im new with all this n ive always wanted a mustang n with it notworkin riteits kinda hard cuzi live with a chevy fan nim always getn **** for my stang so im hopin this will fix the problem thanks so much!
K
kylem40
21
#16
  • Jul 18, 2009
  • #16
but im goin to go im guna c if that fixes it n i will let you guys no thanks again
apollo12
155
port st.lucie fla
Jul 18, 2009
#17
  • Jul 18, 2009
  • #17
did it work?
apollo12
155
port st.lucie fla
Jul 18, 2009
#18
  • Jul 18, 2009
  • #18
almost forgot if your using a different distributor in the "93" motor make sure the distributor gear is the same
K
kylem40
21
#19
  • Jul 18, 2009
  • #19
I got it goin it ran awesome it had power like crazy but then my starter went out on me n Idk if my battery is goin bad or my alternator is goin out im thinkn of looking for a newer Stang to
K
kylem40
21
#20
  • Jul 18, 2009
  • #20
if I take the positive cable off the battery shudnt my Stang keep running off the alternator or is it the ground I take off to c if it stays running?
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
  • brandyn200
  • Jun 20, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
  • dan50
  • Jul 18, 2026
dan50
