Need help!!!
  • Thread starter Thread starter bigjohhnn
  • Start date Start date Jan 24, 2010
bigjohhnn
  • Jan 24, 2010
i have an 88 gt with jasper motor maybe 87 motor not sure. i have a b303 cam with roller rockers and my car runs like crap. have to shift early, it put puts like the motor breaks up. cuts off sometimes. someone told me the cam is not meant for the heads so what can do to fix this. maybe a303 cam? also can i chip it with an a303 cam. my engine has no mass airflow sensor.
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 24, 2010
  • Jan 24, 2010
Try checking all your vacuum hoses and clean the idle control valve if that still does not work try turning up your idle to 900 rpm and if that does not help the you may have a rich condition and may need to install an adjustable fuel pressure regulator so you adjust the pressure so it will not run rich. The cam you have would work better with better heads but that's not the problem so the cam is okay. Good luck keep me posted.
Chrome_Rust
530
Findlay, Ohio
Jan 25, 2010
  • Jan 25, 2010
the Speed Density computer can not compensate for drastic changes in the airflow characteristics of the engine. Pull the B303 out and install a stock cam, or convert to Mass Airflow. A 1989 harness would be a direct swap if memory serves me. That is the problem. No if's and's or but's....
Good luck!
bigjohhnn
  • Jan 25, 2010
i know its the cams ive done everything there possibly is to do in tryin to fix it but i found the owner and he said it is the cams. and if i go mass airflow he said chip it to 87. i heard something bout an a303 but idk. the 302 is bored 30 over so idk if the heads on there are stock or not. i was thinkin bout putting on a trickflow stage 1 cam also
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
