NEED HELP
  • Thread starter Thread starter bubba3
  • Start date Start date Mar 19, 2010
bubba3
  • Mar 19, 2010
I just baught a 92 5.0 and it will not start i changed the plugs and coil. It is getting spark and fuel but will not start. any suggestions will help thanks bubba.
ratio411
3,870
73
109
Pensacola FL
Mar 19, 2010
  • Mar 19, 2010
How did you confirm it is getting fuel?
Will it start with starting fluid?
Fuel, fire, and compression is what you need to run an engine.
If you are positive you have both fuel and fire, then compresson is all that is left.
A big part of compression is cam timing. Is it possible that the timing chain jumped?
HISSIN50
34
129
Mar 20, 2010
  • Mar 20, 2010
http://www.stangnet.com/mustang-for...o-start-checklist-fuel-injected-mustangs.html
bubba3
  • Mar 22, 2010
well i checked the timing and it looked dead on. So i do not know what to do. I am thinking it might be the computer so my buddy is bringing his over tomorrow to try it. So i will see if that does it. I dont know if a sensor or something will keep it from cranking.
89CobraGT
113
Winnipeg manitoba
Mar 22, 2010
  • Mar 22, 2010
So is the starter cranking? its most likely not your computer.
bubba3
  • Mar 22, 2010
well it turns over fine just sounds like its not getting fire. but i took the plugs out and they are. So i am so lost now.
bubba3
  • Mar 22, 2010
I took the plugs and and turned the car over and the cylinders were mistying fuel. but i have not tried starting fluid.
89CobraGT
113
Winnipeg manitoba
Mar 22, 2010
  • Mar 22, 2010
http://www.stangnet.com/mustang-for...o-start-checklist-fuel-injected-mustangs.html Try going over the checklist it might be something simple.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
Idle problem
  • miser143
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
