Need help
Yeah, the stock lines are next to impossible to find. After many years and the heat of the exhaust, they become brittle and present a fire hazard risk.
This thread discusses the alternative with part numbers: https://www.stangnet.com/mustang-forums/threads/1995-gt-rubber-fuel-lines.877769/
You'll wind up with a set of braided lines to the rails, which should prove much more safe and reliable. There are some hassles with the larger line fitting, which will require some cutting to use a compression-type AN fitting or some alteration of the fitting itself to clear the oddball flares at the end of the hard-line. I can describe more if this is a route you're interested in.
Thanks jozsefsz I am not a mechanic I been doing research may have someone to make up the original fuel lines. Part # 640863 fits chevys also # 641303 1/4 #640903 3/8 #640873 Ford return side no size specified. Thinking can that company make them thinner to fit at firewall then I would ask the person if he could attach the fittings to the hoses if all the fittings are correct. Will all 4#fit both ends of hoses and have locking devices for safety ? Thanks padlock
Hi, can I use Fragola ptfe fuel hose - 6AN part # 375030 30” long with one end 45 other end straight on 95 gt5.0 thanks for the help. I purchased part numbers 640863 641303 640903 640873 640853 Padlock
