  • 1994 - 1995 Specific Tech
Need Radiator overflow specs please
  • Thread starter Thread starter Dan95-5.0
  • Start date Start date Feb 19, 2007
Dan95-5.0
1,110
Manitoba, Canada
Feb 19, 2007
  • Feb 19, 2007
i want to replace that ugly looking radiator overflow tank and bracket with something a little more sleek looking.
this is the style that i want to get but i need some info regarding the stocker first.
how much does the stock tank hold?
how long is the stocker (from the top of the cap to the bottom)?
also, i have to disable the low coolant light because it wont work with my new overflow tube. i've read that i can just unplug the connector on the overflow cap and i wont get the ligh on the dash? True or False?
thanks for the help guys.
i'll post up some pics this spring when i put it in.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Feb 19, 2007
  • Feb 19, 2007
true
Suspect
256
GA.
Feb 19, 2007
  • Feb 19, 2007
hey man lemme know if u want that same one cuz i have one thats been sitting forever.
T
tjh566
608
Northern Va
Feb 19, 2007
  • Feb 19, 2007
why dont you just measure your stocker?
9
95Mustang302
302
  • Feb 19, 2007
i'm just going to use a universal summit one without the sensor.
Pokageek
2,767
MA, USA
Feb 19, 2007
  • Feb 19, 2007
Here ya go:
http://www.cantonracingproducts.com/tanks/mustang_tank.html
Why not just put something like this in the fenderwell or somewhere and get it out of the engine bay altogether?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-G1472&N=700+115&autoview=sku
HISSIN50
34
129
Feb 19, 2007
  • Feb 19, 2007
Dan, great thread my man. I was checking things out earlier while trying to figure out how to do a cowl FP gauge without any hole making ). I want to put a bottle in the passenger fenderwell but cant figure out how to access it decently.
FWIW, IIRC some folks have used the windshield washer reservoir. I think they even said the low coolant sensor can be stuffed in there. Just something to ponder.
Oh, my thing is that the stock bottle holds a ton of fluid. Most of the cheaper generic alum versions don't hold much.
Good luck.
ProKiller
3,064
15
78
PA
Feb 20, 2007
  • Feb 20, 2007
+1 about the windsheild washer reservoir. There was a write of someone doing this. IIRC it was 95snoozer who had a good thread about it.
ProKiller
3,064
15
78
PA
Feb 20, 2007
  • Feb 20, 2007
oops, double post
Dan95-5.0
1,110
Manitoba, Canada
Feb 20, 2007
#10
  • Feb 20, 2007
  • #10
let me know the specs on the one you have and how much. send me a PM.
i would measure my stock one but the car is in storage right now and i dont have access to it. otherwise i would be all over that.
i like that idea of using the washer reservoir but i would still like to be able to use the washer fluid even tho i dont remember the last time i did LOL
the biggest i have seen is 50oz
the amount of room i have in my fenders wont be enough to put one because of all the wiring i stuffed in there.
looking at the Canton fox tank from that link posted above, the dimensions are 13.75" H x 3.25" W x 2.5" D so i'll look for something close to that
Bosko5.0
1,067
longwood, FL
Feb 20, 2007
#11
  • Feb 20, 2007
  • #11
i believe the stock one is a 1 1/4 gallon, since 1/2 gal. fills to between hot/cold fill level. i took myne off to put in a new radiator in.
P
Mishimoto Radiator leak 1987 Foxbody 5.0
  • PHoffman
  • Jan 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 18, 2025
Trogdor
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
