Need Some Electrical Help
  • Thread starter Thread starter toosmooth
  • Start date Start date Aug 29, 2006
T
toosmooth
  • Aug 29, 2006
her it goes, just got a .030 motor done with speed pro pistons,b-cam,gt-40 heads and trickflow intake with stock plugs and maf. dropped the motor in and got some loping,probably a vacuum, but decided to get a new engine harness being the one i had was butchered pretty bad, before changing the harness i had to ground out the green wire on the eec to run the fuel pump being it did not come on, now with the new harness,injector harness and 02 harness i cant get it to spark. added three grounds to the block being i did a 3g upgrade also got a new coil and eec being that one smelled fried and i thought it would solve my fuel pump problem,also noticed that the orange wire going to the speed sensor cought on fire with the previous owner and the pink wire to the fuel pump was melted off prior to me grounding it out to run it, sorry guys just trying to cover all fields i will make it a bit shorter. now with the new harness i have to jump the pink wire for the fuel pump to turn on and now i have no spark, already checked the coil and tfi and its good, also swapped out the ignition switch and nothing no spark, i do have fuel pressure though, so i decided to hot wire my car to see if it would start and after unpluging the igntion module and jumping all the wires i almost got it to start by spraying the intake, what the hell is going on please help.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 29, 2006
  • Aug 29, 2006
You are missing two necessary things to help resolve your problem.
1.) Punctuation - your post is very hard to read without it, and electrical problems are difficult enough without having to translate someone's words into sentences. Repost with punctuation so we can understand your problem.
2.) No model year of your car. The wiring changed several times between 86 and 95. There are no clues as to the year of your car & the wiring.
T
toosmooth
  • Aug 30, 2006
sorry will repost
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
