need some help with points!
  • Thread starter Thread starter KTM_43
  • Start date Start date Jun 3, 2005
K
KTM_43
20
Oregon
Jun 3, 2005
  • Jun 3, 2005
Just changed my points,cap, wires and plugs, and the spark plug have no spark! So I checked the points and they aren't moving when I turn over the car? Heard that I need to change the Condenser? What Am I doing wrong? How do I make it work? Not sure what to do next!
68 mustang coupe ( project car)
hotrodnut
672
North Florida
Jun 3, 2005
  • Jun 3, 2005
If your points aren't moving you need to set the gap correctly. I'm not sure what it needs to be for your car but I'd say .015- .018" gap should get it started. A dwell gauge is the best way to set points after it's up and running.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Jun 3, 2005
  • Jun 3, 2005
Points and condensor should always be treated as a unit and replaced together and they are cheap enough to do so, that's the first thing. Second, if you do not have a proper gauge and know the gap then setting the points is next to impossible, especially if you are running the old school upgrade and have dual points. Now, a match book cover is about the right thickness and can be used in a pinch to get them close enough to start the car but they should be properly gapped. If they aren't enough the car won't turn, if they are too much you will get backfires.
Honestly your best bet is to switch over to a Pertronix system. Installation is a no brainer and it takes even less time then you'll spend gapping the points properly. I have never been happier since I did it and I enjoyed tuning the car the way it was. If you have the money I would suggest you do so and keep those new points and condensor in an emergency trunk kit with a flat head screwdriver like I do just in case years from now the pertronix does go bad and you are stranded. Old school is still the best way to get you back up and running in a pinch but new school is the better way to go fro day to day reliability.
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Jun 3, 2005
  • Jun 3, 2005
I think you are in the same town as me. If so, then i will offer any help I can give. I dont know much about points, I switched to a duraspark set up.
anyways, email me if you need to.
hungrymunky @hotmail
chepsk8
2,203
Easton, PA
Jun 3, 2005
  • Jun 3, 2005
Single diaghram on the distributor, .018 gap. Dual diaphram, .021 gap.
I converted both 'Stangs to the Unilite under-cap system.
Wow, someone still has points!
K
KTM_43
20
Oregon
Jun 3, 2005
  • Jun 3, 2005
If it make you feel any better I just got the car about 3 week ago! So I've just began to touch is monster!
Pakrat
3,843
Jun 6, 2005
  • Jun 6, 2005
READ: I dont know much about points, but I recognize the name "girl" when I see it. Thus the offer of help.
Just kiddin HM.
Pakrat
3,843
Jun 6, 2005
  • Jun 6, 2005
So did I up until last year Dan, I never replace a working part just for the sake of it. Maybe I should be called the cheap one.
hungrymonkey
12
108
Oregon.
Jun 6, 2005
  • Jun 6, 2005
Just kiddin HM.
Easy.
actually its a fairly small town.
chepsk8
2,203
Easton, PA
Jun 7, 2005
#10
  • Jun 7, 2005
  • #10
Nah, Pak, I'm the "Scrooge" of this forum!
Just findinf someone with points is a rarity now-a-days!
Whisky - How is your pony progressing?
A
a.vannoy
90
#11
  • Jun 7, 2005
  • #11
Sounds like you didnt set them up right, the part that contacts the distributor lobe at its highest point has to make contact as they open and thats where you set the gap. Hard to explain but gonna try. The thing the rotor sits on is the lobe, it is shaped like a hexagon. When you set the points the little plastic tab must hit this and open up to the gap you set.
To get the points where they will matchup to the lobe you have to ethier bump the motor,( or with engine and key off) turn it at the crank with a ratchet or turn the fan belt by hand (I usually do it this way). If you cant understand this and noone can explain it better I will email you a drawing.
A
a.vannoy
90
#12
  • Jun 7, 2005
  • #12
here you go
http://home.earthlink.net/~goodspeeds/POINTS.HTM
K
KTM_43
20
Oregon
Jun 7, 2005
#13
  • Jun 7, 2005
  • #13
Weee! She is up and workin!! I think she is purring like a kitten! Hopeing to take her out some time this week (prayin not to get stuck) Changed the oil for the first time and found 3 large? (size of a eraser top) pieces in it. Geeez! Just want to get her out on the road once before any big over haulin'. Anyway thanks every one for your tips, they were a big help. I'm sure you'll hear from me soon on the next project I'll be trying.
Pakrat
3,843
Jun 7, 2005
#14
  • Jun 7, 2005
  • #14
Great news, feels good and satisfying don't it? So what was the issue exactly? Just a bad gapping?
A
a.vannoy
90
#15
  • Jun 7, 2005
  • #15
Pieces of what?
RGS0907
429
New Jersey
Jun 8, 2005
#16
  • Jun 8, 2005
  • #16
I'm still running dual points in my 428... I added an MSD about 15 years ago & never need to look at them. What ain't broke...
K
KTM_43
20
Oregon
Jun 8, 2005
#17
  • Jun 8, 2005
  • #17
pak, yes it was the gapping and also the belts and the timeing! They all needed to be ajusted! A. van, as for what not sure I found them in the oil filter and they hard was a rock possibly metal but not for sure!
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
  • Mindseye007
  • Aug 16, 2026
Mindseye007
