Need some help with the GTP guys....
drakesdad
961
Oregon OHIO
Wife called when I was at work and said the car was hesitating...
I took it to work today and had a friend bring his scanner.......said it was "missing" on 1, 3, and 4...........He had some extra coil packs at home so we went and got them.....switched them out and still the same....got home and switched the Duralast wires for free ....cheap autozone lifetime warranty 7mm wires.....looked at 1 and 3 plug and it the looked fine....not black....not white.......poured 1 bottle of injector cleaner in.......changed the fuel filter for the heck of it.....that was a pain 'cause it was rusted on......just for the heck of it cleaned MAF and pulled all 3 coil packs back off and cleaned the module with alcohol............still the same sputter and miss.......Same friend has some extra fuel injectors he will give me but I can't believe 3 would be back on different banks..........also can't believe a bad tank of gas from Sterlings could be behind it.......If you have any idea's or history I'd appreciate the input for this is the wife's car and baby wagon.....
Thanks in advance guys,
Will
