need some help
  • Thread starter Thread starter 93GTosu
  • Start date Start date Dec 29, 2006
93GTosu
183
  • Dec 29, 2006
well my 93 GT has been garaged for winter, and i'm home for christmas break this weekend. Before i put it away, i was having troubles with it (it stalled and when i would try and start it up it had major surging idle problems and then would die). started up fine and idle perfect this week. Well I figured i'd start on my head swap while i had some free time and maybe try and figure out what the problem was with it. Well anyways, i jacked up the front end and saw a few drops of oil under the rear drain plug. Also the plate on the front of the tranny is missing a bolt, and is pulled maybe 1/2 inch out. the oil looks like its running down this plate from the back of the engine somewhere. no more has leaked, and it didnt appear until i jacked it up (i definitly checked for any leaks before i did anything).
what do you guys think?
93GTosu
183
  • Dec 30, 2006
back up top while i sleep
i can get pics, does anyone understand what i'm saying?
obviously the bold missing from the tranny is bad.
but are there any common places where oil would leak from and drain down this place? nothing is off the motor yet (heads,intake,etc.). i have ~37-40 oil press on start-up, 10w30 mobil1 synthetic fwiw and was told this is "ok."
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 30, 2006
  • Dec 30, 2006
sounds like it could be a rear main seal leak. also with your idle i would suspect the TB needs to be cleaned and so does you IAC.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Tuesday at 7:31 PM
mikeah
