Need some help
  • Thread starter Thread starter suki243
  • Start date Start date Aug 24, 2008
suki243
662
Southern California
Aug 24, 2008
  • Aug 24, 2008
So last night i was driving and i stupidly put the car into the lower gear, (automatic) when i did so all the interior lights shorted out, like the instrument panel and the light that is under the shifter. I then smelt smoke and burning plastic. i turned off the car and lights and sat there for a bit, tried it again, the burning stopped.
I think what happened is when i put in the carpet i didn't leave enough slack for the light wire that goes to the shifter and it must've exposed itself a little and shorted out against the floor. This also isn't a stock wiring system, its an EZ wiring, and my instrument panel lights are connected directly to the light switch.
I checked the wire from switch to lights for continuity and it was fine. I checked the fuses and they were fine. the headlights, turn signals and all still work just not the interior lights. I'd do the whole 9 yards and pull everything out and what not but i'm not at home, i'm at school and i didn't bring all the tools with me.
Therefore, I think i burned out the light switch. What do you guys think?
P.s. Next time i'll install an inline fuse between the interior lights and the light switch
T
truck90278
382
Redondo Beach, CA
Aug 24, 2008
  • Aug 24, 2008
Your probably right, however I would be concerned that you can have a short of that magnatude and NOT blow a fuse, that's what they are for. If you replace the switch, you still have the short, need to fix that. If you burned the wire up, you may have many places in the circuit that can short out.
suki243
662
Southern California
Aug 24, 2008
  • Aug 24, 2008
For the time being i disconnected the wire that goes to shifter light, i cut it off and wrapped it in electrical tape. it was spliced with instrument light wire.
I think the reason the fuse didn't blow was because it got to the switch first. I didn't put a fuse between the lights and the switch.
And rather only one part of the switch burned cause everything is alright still
Tim65GT
1,149
West Texas
Aug 24, 2008
  • Aug 24, 2008
Just buy a 5 amp fuse and holder and temporarily wire it up to the headlight circuit so you have dash lights.
That should hold until you get home and figure out where the fault is and how to fix the root of the problem.
R
runawayabc123
192
Wisconsin
Aug 25, 2008
  • Aug 25, 2008
I am confused, maybe because my pony has a 4 speed manual, but how does down shifting in an auto cause a different light to come on, much less expose a short?
iskwezm
4,159
20
79
Rowland Heights,California
Aug 25, 2008
  • Aug 25, 2008
theres a indicator light on the shifter base.
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
