  • SN95 4.6L Mustang Tech
NEED SUGGESTIONS AND ADVICE!!!
  • Thread starter Thread starter silver04GTstang
  • Start date Start date Aug 18, 2008
silver04GTstang
35
  • Aug 18, 2008
ok, to start off i have a bolt on automatic GT that i had always planned on leaving a bolt on car because i have a fox body i want to start playing with. I have gotten really attached to the GT and have decided that i wan to make it faster too...im the slowest one out of everyone i hang out with(brother has an 03 cobra,buddies with twin turbo 98 cobra, a nasty evo 8, and a friend with a procharged trans am etc etc). well i dont know what to do...i wanna go forced induction with either a procharger or turbo set up...either way its going to be cammed and im going to need a stall and a stronger tranny or a manual...which power adder should i get and which tranny idea should i go with and what whould be an automatic you guys would recomend. and also since im going to be building the motor, what intake chould i go with....i dont wanna blow through the plastic and deffinitly not spry through it...just sounds like a bad idea....any help and ideas from you guys would be helpful... thanks
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 19, 2008
  • Aug 19, 2008
A good tune and a careful driver and you shouldn't have to worry about blowing the intake. But there are some options out there if you want to replace it. If I had my choice I'd find a Bullitt intake but there are other one equally as good.
You are up against some steep competition and honestly it will cost to catch up. Cost wise a supercharger is the way to go...and even bump up to a Kenne Bell. That would take care of your power adder and intake problem all in one. A good tune and you should be OK to about 400 HP. After that you would need to get into the engine. A good blower cam should suffice if you want to dig into the heads.
silver04GTstang
35
  • Aug 19, 2008
im wanting to just skip stage 1 all together and build the engine and get ready for higher boost even if i dont start out with much...my main concern is the transmission...i dont mind an automatic but kinda want a manual...is there any good automatics youd recomend or should i just go with a tko or something? i also cant find a good stall that i would trust if i stayed with the automatic id want a 3200 or so...
D
darkside03gt
851
Sacramento CA
Aug 19, 2008
  • Aug 19, 2008
I would go with a tko. you can get a clutch pedal assy from a wrecked gt. it wont cost you much more then a built auto.
I would go with either vortech/paxton or kb. as i dont really like pro charger much. it is gona cost you some seriouse scratch to catch up to that crowd. I would look into a built shortblock from either livernois, mph, or foxlake with some ported heads and cams.
silver04GTstang
35
  • Aug 26, 2008
you guys think i should just get my 5 speed 5.0 coupe out and build it instead? i just really like my silver car....its a looker and the coupe not so much...
D
darkside03gt
851
Sacramento CA
Aug 26, 2008
  • Aug 26, 2008
no i would build the gt. not much of a fox fan.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Aug 26, 2008
  • Aug 26, 2008
build the GT, mod motors can be complete animals with the right parts
04YELLOWGT
1,135
Indiana
Aug 26, 2008
  • Aug 26, 2008
You should be fine with the stock auto for quite a while. I was running DEEP into the 11s before I even touched mine. I would do a tranny cooler an leave it at that for now and start building up the motor.
As for the intake unless you really start making a crazy amount of boost and start spraying it it should be fine too. I'm making over 14lbs and its held up fine for me and IF I keep my car this year I'm planing on spraying it.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
Aug 27, 2008
  • Aug 27, 2008
silver04GTstang said:
ok, to start off i have a bolt on automatic GT that i had always planned on leaving a bolt on car because i have a fox body i want to start playing with. I have gotten really attached to the GT and have decided that i wan to make it faster too...im the slowest one out of everyone i hang out with(brother has an 03 cobra,buddies with twin turbo 98 cobra, a nasty evo 8, and a friend with a procharged trans am etc etc). s
Ha sounds like me. I have a 5.0, a silver GT and all my friend's kick my ass in their faster cars.
In the end i decided to leave it alone. By the time i was done soaking money into the car to make it faster, i could have bought a terminator or built a nasty driveline in my Fox.
SO...i just did shifter, exhaust and brakes and called it a day. Meanwhile i'm searching for an '04 Cobra driveline for my 5.0
DAKDOG99
37
COLUMBIA, S.C.
Aug 27, 2008
#10
  • Aug 27, 2008
  • #10
I put a P&A street/strip valve body in my auto. I also installed a deep trans pan, a trans cooler, and an edge racing 3200 stall converter. If I had to do it again, I would have just bought the whole trans set up from P&A. The valve body is not really for the street. It only likes WOT. In town it sucks.
If this is just a street driver it would be more fun with a 5 speed in it.
fast97gt
1,082
north carolina
Aug 27, 2008
#11
  • Aug 27, 2008
  • #11
umm i have both the sn95 and a 89 fox. but i found it easier cheaper to build the fox. ive spent 5 grand and have a car that runs 7.6s on mickey tomphson e/t street tires in the 1/8. but its all personal prefrence, its a 306 with afr heads, comp cams extreme energy cam, trple spring valve springs, forged bottom end, barry gant 850 carb, and a 225 shot for now, w/o the bottle it made 551.4hp and 532tq at the flywheel. mated to a c4 built by a local shop, and a 3200 stall, yea i think it runs pretty good.
silver04GTstang
35
#12
  • Aug 27, 2008
  • #12
i gotta a geo for my daily driver and my plans were to make both cars nasty while im still young and living at home...so i think for now im gonna get the fox going and make it fast....i was thinking maybe a 331, the gt 40x turbo swirl heads, E cam, Cobra intake?, and some spray for now...then later when i get the money throw on a blower...and shortly after...some stage 3 heads and cams for the GT and a stall...what do you guys know about the trick flow kits and how they work with blowers on the 5.0 cars...and how do you think the 5.0 will run with the setup im planning on?
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
1996 v6-v8 swap
  • jujuonurmom
  • Oct 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2025
jujuonurmom
J
