T TN90 New Member Nov 2, 2006 1 0 2 Feb 1, 2010 #1 Feb 1, 2010 #1 I need to replace the A/C hose's protective cover where can I buy one made for a 90 5.0 mustang or what can I use instead? Thanks in advance...
88-378 Member Aug 10, 2007 14 2 16 Alpharetta, GA Feb 2, 2010 #2 Feb 2, 2010 #2 go to home depot or lowes and get the pipe insulation that is split length wise with glue to join the seem.
glowstang93 20+ Year Stangneter Feb 9, 2003 853 8 39 Illinois Feb 4, 2010 #3 Feb 4, 2010 #3 I tried that it and the heat from the manifold melted the foam. I ended up just putting wire loom on it to cover it at least.
F fordfreak300 New Member May 29, 2004 10 0 0 Los Angeles Feb 6, 2010 #4 Feb 6, 2010 #4 They have some designed to hold up to high heat. It is not split already though. You will have to cut it length wise your self to get it to go on. Home Depot has it. Make sure you check that it is rated for high heat and you are good.
4G-KDMP 10 Year Member Jul 23, 2005 935 19 39 CA Feb 6, 2010 #5 Feb 6, 2010 #5 Is the cover really needed? What would be the ill effects if it not there?
