brianj5600
Very nice! I want 15" wheels someday, so I am keeping small rotors. The Mach1 wheels were cheap and will do for now.
ultrastang said:It actually goes back a year earlier than that. 1968 was the first year the disc brake equipped Mustangs switched from the K/H 4-piston fixed-mount caliper to a single large piston floating caliper.
I'm pretty certain the '68-'73 mounting points on the spindles are the same on the '68-'73 disc brake spindles as the mounting points on the '75-'80 Granada/Monarch & '74-'77 Maverick/Comet spindles.
However, --for me, I'm staying away from the pre-'70 model spindles with their thinner spindle pins. I can't keep someone from putting the adapter brackets on a '68/'69 disc brake spindle. All I can say is you've been warned.I'm more interested in a safer assembly than turning a fast buck. I don't make a big income at my job, but I'm not so desperate for money that I would push this conversion off on someone with a spindle that's really not up to the task.
All Mustang spindles (drum or disc brake) from '64½-1969, have a thinner, weaker design than the '70-73 drum or disc brake spindles. In 1970, Ford beefed the spindles up on both drum and disc brake equipped models, because the spindle pins of the pre-'70 Mustangs have a weaker design that can break off at the upright/steering arm.
In a street application, the '64½-'69 spindles MAY run without incident. If you are racing opentrack though, it will just be a matter of time before disaster strikes. --So to me, I just prefer to stay away from them and not chance it either way.
In ANY case, whatever you have or setup you're running, if your spindles are used, take them to a machine shop and have them magnaflux-checked for stress cracks prior to putting the new brake system on.
I wouldn't mind making an adapter bracket for a '70-'73 drum brake spindle. What year model is the drum spindle you have?
www.ultrastang.com
DarkBuddha said:Nice looking brackets Steve! You know I'm interested, but only if it will allow me to continue to use my '70 disc brake spindle. As Bryan said, shouldn't your bracket also work on '70-'73 disc spindles as well?
Let me know...
Fatigue cycle is one of the properties that I was referring to as well as corrosion and temperature cycling all of these. As far as the use of aluminum on jets and other applications, I agree it is the best material for the application but I am willing to bet that the brake hardware is steel.Sundance said:My only arguement for aluminum vs. steel, and a point that thus far has not been mentioned, is fatigue cycles. Without that consideration I would agree that the strength would be the same.
brianj5600 said:LMan, I have Granada rotors from Degins. What MC are you using?
Has a Corvette been built in the last 23 years with that did not use aluminum for spindle and control arms. I think there is plenty of meat on G2C brackets.
