  • SN95 4.6L Mustang Tech
Needing help
  • Thread starter Thread starter GsxrPanda13
  • Start date Start date Sep 26, 2018
G
GsxrPanda13
Hendersonville
Sep 26, 2018
  • Sep 26, 2018
hi I have a 2000 Mustang GT. I have a misfire on cylinder 3. I have changed the coil pack and the spark plug it cleared out later on that day it started doing it again. Could a bad injector or a leaking manifold cause this problem as well
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 26, 2018
  • Sep 26, 2018
Yes it could be an injector as well as other "possible" causes such as low compression.
Consider using a mechanic's stethoscope to listen for the "click" of the injector pulse. If no click then a "noid" style test light can easily test for the electrically pulse from the PCM.
Note, it's possible for an injector to be mechanically clogged. If so, consider an injector cleaning and flow test service such as InjectorRX.com. Once cleaned and tested they are as good as new (but cheaper).
Reactions: GsxrPanda13
G
GsxrPanda13
Hendersonville
Sep 27, 2018
  • Sep 27, 2018
I changed the plugs and used an injector cleaner. I am going to test drive a and see what it does now the injectors seem like they are working
BarnStang
1,260
Hagerstown, MD
Sep 27, 2018
  • Sep 27, 2018
I chased a misfire for weeks thinking it was something serious on #7. New wires. They "looked" ok, but put a new set of Ford Racing 8mm wires on and never ran better. Make sure to follow/verify where each wire lands on the coil pack. They are numbered.
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Which cylinder is which? 3.8L 2004
  • joeybuddy96
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 24, 2026
joeybuddy96
J
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 23, 2026
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
