Neutral safety switch question
  • Thread starter Thread starter Falcon79
  • Start date Start date Feb 2, 2010
Falcon79
214
Dallas, TX
Feb 2, 2010
  • Feb 2, 2010
I have a 68 mustang with a '72 C4, the neutral safety switch came with the tranny. The plug matches my wiring harness but I'm not getting the rear parking lights to come on. Do i need to switch the neutral safety switch to a 68 year switch?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Feb 3, 2010
  • Feb 3, 2010
First, check to see whether power is getting to the switch, at the plug, and if it is, check to see whether the switch is sending power back to the plug. If you are, then you need to trace the wiring harness to the rear, to find the problem.
Falcon79
214
Dallas, TX
Feb 3, 2010
  • Feb 3, 2010
I just replaced the entire rear harness wiring so I ruled that one out. I think the question i was trying ot get answered was about the compatibility of a switch from a '70+ C4 to a '68 wiring harness, the plugs are the same but the mustang vendors sell them as two different parts. one fits years 1967-1969, the other fits years 1970-1973. Are they installed differently? on my c4 the switch is on the upper side of the shift linkage.
2+2GT
3,333
10
79
Feb 3, 2010
  • Feb 3, 2010
The switches are compatible. Never assume something works just because it's new. Under 5 minutes with a test probe will solve your mystery.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
