  • 1994 - 1995 Specific Tech
New 3.73's...
  • Thread starter Thread starter click
  • Start date Start date Sep 8, 2005
C
click
142
  • Sep 8, 2005
Hey i decided to finally go for some new gears, since the 2.73's or whatever we have stock are POS. What gears do most people use? I saw motive gears which i heard we good on summit for 180. Do those include the the shims, pinion nut etc. If they don't what exactly would i need. Like traction lock, or a kit whatever.
Mustang tuning has this kit for the motive gears
http://mustangtuning.com/rearendrebuild.html
would that be it then, the 3.73's for 180 and the kit for 90. Keep in mind my car has 110k miles on it.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 8, 2005
  • Sep 8, 2005
Ford racing gears are what you want. Might wanna look into a bearing rebuild kit and a trac lock rebuild kit too.
95COBRA241
339
Delray Beach, FL
Sep 8, 2005
  • Sep 8, 2005
deleted cause i duplicated my response.
95COBRA241
339
Delray Beach, FL
Sep 8, 2005
  • Sep 8, 2005
The old cliche for our type of mustangs (non modular) is 3.73's for stick and 4.10's for auto. Ford uses 2.73's to satisfy all the old grocery getters who want a low crusing rpm in the same manner that they tune the car from factory to use 87 octane.
I have a stick and use 3.55's I am very satisfied with them. I have also had 3.73's and 4.10's on other stick cars. I went with 3.55's because I knew eventually with this car I would be adding a 347 and later a vortech. The additional tq from the 347 will make up for the lower tq multiplication of the 3.55's vs 3.73's with a 302 motor. IMO only.
VulcanGT
Lexington, KY
Sep 8, 2005
  • Sep 8, 2005
if u have a manual tranny, id say go with 3.73's. my old vert was a stick with 3.73's and it was kick-ass. if u have an auto, 3.73's are good, but ive heard that 4.10's are the way to go if u have an auto. my auto coupe with 3.73's does fine for me, but id like to see what 4.10's are like
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 8, 2005
  • Sep 8, 2005
Go to www.gefracing.com and get some FMS 3.73's. Should run you about 160 shipped. FMS are easy to install and SOOO worth it. Forget motive.
Scott
Blackened302
1,439
South TX
Sep 8, 2005
  • Sep 8, 2005
what's the change in gas mileage when going from the stock gears to 3.73's? i'm poor and can't afford to spend more on gas.
HGFireHazard
460
Michigan
Sep 9, 2005
  • Sep 9, 2005
Most people say they lose 1 or 2 on the freeway and gain 1 or 2 in the city. However, you shouldn't have purchased a sports car that you wanted to upgrade if you were worried about gas
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 9, 2005
  • Sep 9, 2005
Umm no one anticipated paying between $3-5 dollars a gallon either depending on location so keep that in mind.
Blackened302
1,439
South TX
Sep 9, 2005
#10
  • Sep 9, 2005
  • #10
that's right!
a lot of you guys say the same ol' shiet when it comes to gas mileage--"it's a sportscar, bla bla bla, i'm an idiot and don't take gas prices into consideration." but, wytstang is exactly right. who the hell thought we'd be paying triple for gas?
this is the first time i get to use that emoticon, so here it goes again...
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 9, 2005
#11
  • Sep 9, 2005
  • #11
If your mileage went to 10mpg, it would still be worth it every time you press the gas pedal.....
I didn't notice any difference. Still got 18mpg in the city.
Scott
RIO5.0
6,892
N.H.
Sep 9, 2005
#12
  • Sep 9, 2005
  • #12
If the state of tune is good you dont really loose jack...Hell, Im around 18-21 with no highway driving and 373's...and i had 355's and swapped these in...
I would def go FRPP for the gears, most are gonna say that...they work....axle seals and a pinion seal should be swapped out as those are cheap...If the rears quiet, I'd leave the bearing's right alone, as long as everything looks good with the bearing's/races at disassy...the dif's are pretty rugged....you dont really see alot of post on junked out dif's, hence my thinking....I left everything alone in 3 swaps without a peep out of it...
Minimum needed...
gears
speedo gear
trak-loc kit
friction modifer
dif lube
axle/pinion seals
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
