Hey eveyone, I just had a new longblock built by a local engine builder and I thought everything was going to great until I actually had it installed. He dyno's every engine he builds at the shop. When he built it, he said he had to way to dyno it with an EFI intake, so he used a carb to dyno it then put the intake on it. With the carb it dyno'd at 442 hp, which I thought would be nice. Well, when it was actually brought to the shop to swap the engine, there were a whole heap of problems. Just in case you are wondering, the engine builder only builds engines. He does not install them. So, a few problems started happening when the installers called and said the water pump wont fit because of the timing cover. Then needed a new alternator. Then needed an intake spacer because the valve covers were too tall. So, after all said and done, I drove the car home and noticed that it ran like trash. I couldn't bring it right back to the shop because I picked it up Friday right at closing, so they arent open until tomorrow. When I was driving home, my gauges didnt even work. Then when I tried to turn on my lights, they wouldnt. So, when I stopped to get get gas and check it out, the car wouldnt turn on. I had to have it jumped. The dash lights finally turned on, then started flashing bright and dim. It seemed as my alternator wasnt quite doing to job. But the car actually drove. Just horribly. So I limped home and it completely died right before I got to my street. Died to the point where it just shut off and I couldn't even roll start it by kicking it in gear. So, I had it jumped again and drove it home. I made sure connections were good and this morning, it seemed as one of the alternator plugs were loose, so I pushed it in and made sure everything was tight and started her up. The only reason she started was because I charged the battery last night. Well, I tested voltage with a DMM at idle and it was at 14.4. Turned it off and it read 12.5. Turned back on and tested at 3-4k rpm and it still tested at 14.4. Turned on lights and they worked fine and the gauges were in tact. Then I decided to take it for a drive and it ran like trash. It seriously felt like it had 100hp. I didn't immediately get on it, I let it warm up as I cruised around the block. I actually never went WOT, but even at maybe 75% throttle, there was no power. In neutral, she revs up like she wants so fast and smooth, but in gear, she just doesnt perform. I know I have to let it break in, so i didn't go crazy, but general driveability should be better than this. The shop mentioned that they put her at stock timing. I know that the builder bumped it during the dyno pulls, but I still dont think it should run this poorly. I believe at stock timing, he got almost 400hp. Now, I have stock a stock computer, and havent gotten a chip or anything. They said I don't need one and it should calibrate itself and drive fine. Are they just wrong? To give you guys the best analogy of what happens, its like a Honda that gets real loud, but doesn't move. Please let me know what you guys think.
Don't be discouraged..well do.. and then make it better. The builders /tuners dumping it on you are a bunch of A holes and you should get your money back.
