  • 1994 - 1995 Specific Tech
New Alternator...Same Problem
  • Thread starter Thread starter Danman765432
  • Start date Start date May 25, 2007
D
Danman765432
471
Nutley, NJ
May 25, 2007
  • May 25, 2007
Well I got my Alterstart/ Load Boss 200 amp alternator in today and I installed it....I proceeded to wash my car after it was installed and working fine.
When I started the car up after I installed it, it made a loud squeeking noise and the voltmeter would climb up higher and higher until it was to full voltage and the squeeking stopped.
I thought this was due to water getting on my alternator but now i am confused....I have installed this shield that you will see in the next two pictures.
Now when I started looking around I noticed a lot of water sitting on my abs unit...in the picture below.
Then this is the car...sorry for whoring
Also if anyone can just please help me out a little bit here...I am so lost on what it could be now.
Bosko5.0
1,067
longwood, FL
May 25, 2007
  • May 25, 2007
Are you sure it is not another pulley making the noise?
Is your belt too tight?
Did you get water on the pulley making the belt squeel?
Car looks good.
D
Danman765432
471
Nutley, NJ
May 26, 2007
  • May 26, 2007
Car looks good.
1. I am pretty sure it is the alternator pulley just because it is also having charging issues....I am going to try and get a video of it so you guys can see but it happens quick and i normally dont have a camera on me.
2. I did just replace the belt but it also did it with the old one.
3. I am really not to sure if it was on the pulley or not...I didnt take notice to that since I was in a scramble to get my hood popped.
Also when my car is shifting from 1 to 2nd at wot sometimes, it squels to but I think that is just the belt even though it did that with my old and new one....
Ill see if I can try and figure something out but guys dont be shy to throw out some more ideas.
D
Danman765432
471
Nutley, NJ
Jun 4, 2007
  • Jun 4, 2007
Well guys I think it is my belt slipping from being wet....here is a few pictures and a video of what it does.... In the begining of the video you will hear a chirp when i start the car... you will barely hear it over the door open ding. Then when you hear the door open ding again is when it makes the loud squeek.
http://youtube.com/watch?v=SauHrRx9M2gView attachment 382841otobucket.com/albums/bb133/Danman765432/alt5.jpg[/IMG]
mine and my brothers car (I can't wait till i have enough to get my handling package)
HISSIN50
34
129
Jun 4, 2007
  • Jun 4, 2007
Dan, homie doesnt do videos, but here's one more thing to check. Ensure your pulley alignments are all nuts-on. If one accessory is slightly ****-eyed, the belt can make some noise till it heats up (and can make noise again when there's a load on the engine). I use a machinist's straight edge to check alignment.
Now as to what caused the high voltage reading................ That's scary. If I start seeing anything nearing 15 volts, I'd freak.
Good luck bud.
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Jun 4, 2007
  • Jun 4, 2007
I used to get the belt squeak every time I washed my engine bay. Now I try not to wet it directly (still get a little wet) and no squeaks. Definitely don't get armour all on it or any other rubber protectant spray.
Not sure what you cover up when you wash the engine bay, but I've had luck using plastic grocery bags to cover the alternator, filter housing, distributor, and my alram siren. Maybe I should cover more stuff, but no problems after 10 years.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
