New battery, motor wont turn
Green_Meanie
161
I just replaced my battery, but the motor will not turn. Just before replacing the battery I jumpstarted it with the old battery in. Why will it not turn now?
540 CCA battery
Cables connectors are clean and I checked the voltage on the battery and its normal.
:shrug:
Anyone have an idea?
331 cobra said:
Did you hook the jumpers directly to the battery terminals? That will fry something, I can't remember what it is.
I learned the hard way, you need to use the engine block for the ground piont on the vehicle being jumped.
I grounded to the block when I jumped it.
have you checked the battery cables and the ground cable connection on the block.
try connecting the jumper cable from the NEG side of the battery to the block and see if the engine will crank. if it does, then there is a problem with the ground cable from the battery to the block.
