New Combo Running!
  • Thread starter Thread starter bobbys9350
  • Start date Start date Oct 1, 2006
bobbys9350
472
  • Oct 1, 2006
OK guys i gotta 89 shortblock in my car with 90k miles. here is my setup:
GT40-P heads from 99 explorer
holley adj. fuel pressure regulator
holley systemax intake
EGR valve disconnected
MAC headers, catless h pipe, flows
BBK 70mm TB
NEW frpp #19 inj.
* deleted PCV and single breather in place of oil fill cap
Questions:
1) My idle still surges a little bit up and down. will a tune take care of this and how will they tune it?
2) What should my fuel pressure be at idle? right now its at 32
3)is there any benifit to running a PCV?
4) under ligth acceleration the car "chugs and bucks" What would be causing this.
5) what would be the best plug to run with these heads?
Any help would be GREAT! THANKS A LOT!!! :SNSign:
bobbys9350
472
  • Oct 2, 2006
ANYONE?
DEFWISH
87
Wichita, Ks
Oct 2, 2006
  • Oct 2, 2006
i don't think your pcv hurts any thing, and i would think motorcraft, bosch, or autolite plugs would work, not sure about heat range.
bobbys9350
472
  • Oct 3, 2006
thansk. anyone else?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Oct 3, 2006
  • Oct 3, 2006
Your surging is probably from deleting the PCV valve and replacing it with an open breather on the oil filler. That lets un metered air into the engine. On a MAF car, that's bad. It is probably the cause of your bucking too.
Fuel pressure is too low. 38 psi is a good starting point.
Best plug would be a stock heat range explorer plug.
bobbys9350
472
  • Oct 5, 2006
thanks! if i put the pcv back in and run an oil seperator will that keep oil out of my intake?
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
