new combo
  • Thread starter Thread starter Denny Wiedman
  • Start date Start date Jan 21, 2004
D
Denny Wiedman
110
nj
Jan 21, 2004
  • Jan 21, 2004
just got my new 408w done with street manners in mind, list of things from old 408, same block motorsports A351, steel crank, rods, alum pistons with 9.8.1 comp ratio, 408 cu. in.,roush 200 heads with 250cfm@.500 lift, 180 on the .ex, 263@.600, 186.ex,206 int port cc's, comp hy roller 288-293-236-242-555-576-108, vic jr manifold untouched, 750HP DP, 1\3\4 supercomps, 7qt oil pan, msd billet mech advanced,1.6 rollers, edelbrock water pump, eletric fan, all into c-4 full manual, 10'' 3500 stall converter, 3''x-pipe into 2.50 flows 2 chamber same back tailpipes, #10 fuel line with sump under tank, carter high volume fuel pump, 69mach1, old engine made 400 flywheel, 300 rwhp, almost 400ft lbs@ 3000 with small cam, stealth manifold which i might use again, dyno in spring, how much power this combo will make anybody?. thanks.
12sec67
1,301
San Diego, Ca
Jan 21, 2004
  • Jan 21, 2004
no help....take it to the dyno now cheap as$.... just joking!
'69Stang
1,130
Metro Detroit
Jan 22, 2004
  • Jan 22, 2004
Probably around 475 FWHP @ 5600 RPM's and 500 FWTQ @ 3800 RPM's. That looks like a great cam for a streetable 408w. Nice combo. I hope you have some traction upgrades because that will be a torque monster.
G
GaPonyFarm
663
Columbus, GA
Jan 22, 2004
  • Jan 22, 2004
3500 stall torque converter for "Street Manners"... What friggin' street do you live on?
Sounds like a great ride! I think 475 rwhp, might be just a bit optimistic though..
dolfan87
1,242
Lake Havasu, AZ
Jan 22, 2004
  • Jan 22, 2004
505 Hp, 525lb/ft....that's my guess.
87
Edbert
3,548
32
109
Austin TX
Jan 22, 2004
  • Jan 22, 2004
DOH!
Edbert
3,548
32
109
Austin TX
Jan 22, 2004
  • Jan 22, 2004
I was thinking the same, add in the lack of vacuum advance and mech secondaries too. I tuned mine way down to make it streetable and have functional power brakes.
Yup, I was thinking 525fwhp, you'd be pretty lucky to put down 475 with that (assuming our guesses are right).
D
Denny Wiedman
110
nj
Jan 22, 2004
  • Jan 22, 2004
combo
thanks guys, my converter will stall from 2800 to where ever my power curve is, special JPT 10'' converter, jim says when you mash the pedal look out, my engine guy seems to think 475hp, but who cares i need torque down low from light to light, not worried about 6000 rpms unless i race it once in a while, street car and little race, 500ft lbs is a lot of torque man this thing going to brake something i have a feeling, cant wait to fire it up soon. thanks, what gears should i run on this thing, 3.50 posi now.
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
