Fuel New gas tank leaks ??
  • Thread starter Thread starter 88-90ConVerts
  • Start date Start date Mar 19, 2018
  • Tags Tags
    new gas tank leaks
88-90ConVerts
50
Ponte Vedra,Fl
Mar 19, 2018
  • Mar 19, 2018
I have a 88 LX convert 5.0 and I recently replaced the gas tank with a new sending unit and new 255lb fuel pump, I bought all new seals with new locking rings. Before when I would fill the gas tank up it would leak out the top where the fuel pump is located. I made sure that the new o-ring would seat properly before I installed the new tank. When I filled up is was fine no leaks, but when I topped off and filled it completely to the top it leaked out some where the fuel pump is not where the sending unit is. Is it the o-ring not fully settled yet? I would like hear if anyone else has to his problem thanks.
General karthief
Mod Dude
Aug 25, 2016
28,021
10,646
213
polk county florida
Mar 19, 2018
  • Mar 19, 2018
There is a couple places on top for leaks. Make sure the O ring didn't roll over or get pinched, the vent tube nipple could be leaking also.
88-90ConVerts
50
Ponte Vedra,Fl
Mar 19, 2018
  • Mar 19, 2018
The O-ring on top I made sure didn't roll over also I put a new grommet and vent tube when I replaced the gas tank, When you mention leaking out the nipple are you talking about where it inserts Into The Grommet or where the hose connects on to the nipple?
General karthief
Mod Dude
Aug 25, 2016
28,021
10,646
213
polk county florida
Mar 19, 2018
  • Mar 19, 2018
Both, did you replace the filler neck gasket? Also check the hoses on top. Are you sure the leak is on top of the tank? Or are you smelling fumes.
88-90ConVerts
50
Ponte Vedra,Fl
Mar 19, 2018
  • Mar 19, 2018
Yes I replaced the grommet on the side the sending unit with new o-ring and lock. Plus the gas tank is brand new, and yes it is leaking on top only when I fill it completely full and I mean completely full. That's the only time it leaks if I just fill it up normal without making sure it's completely topped off it doesn't leak seems like when it gets to a certain point on Top that's where it's coming out at and the only thing on top is the O-ring and lock where the fuel pump is and the fuel vent.
General karthief
Mod Dude
Aug 25, 2016
28,021
10,646
213
polk county florida
Mar 19, 2018
  • Mar 19, 2018
Your not supposed to 'top it off'. It's likely overflowing out the vent.
88-90ConVerts
50
Ponte Vedra,Fl
Mar 19, 2018
  • Mar 19, 2018
That's what I figured that's the only time it leaked was when I top it off completely full. So do you think it's coming out of the vent because the vent has a hose that connects on to the nipple I don't see where that would leak out at unless it came out the grommet, but that's new.
General karthief
Mod Dude
Aug 25, 2016
28,021
10,646
213
polk county florida
Mar 19, 2018
  • Mar 19, 2018
When you 'top it off' your filling the tank to a point above the vent so it will bleed out someplace, usually it would fill up your vapor canister, you may have a hose seeping, check the vapor hose from the tank to the canister
88-90ConVerts
50
Ponte Vedra,Fl
Mar 19, 2018
  • Mar 19, 2018
Thanks for help, are you talking about the charcoal canister? And I may have not mentioned this earlier the only place I did notice the leak was on top and it only leaked out a small puddle then stopped.
General karthief
Mod Dude
Aug 25, 2016
28,021
10,646
213
polk county florida
Mar 19, 2018
#10
  • Mar 19, 2018
  • #10
On top of the charcoal canister or the gas tank
88-90ConVerts
50
Ponte Vedra,Fl
Mar 19, 2018
#11
  • Mar 19, 2018
  • #11
Thanks for help.
HotFox
1,067
700
164
SE Michigan
Mar 20, 2018
#12
  • Mar 20, 2018
  • #12
I have experienced a leak around the sending unit because I had to beat the old ring off. This distorted the opening enough on the factory tank that the new ring and seal did not seal properly. It leaked bad so I had to pull it back down and reshape the mouth with a plyers to put the correct amount of pressure on the seal.
Reactions: mustangramair
General karthief
Mod Dude
Aug 25, 2016
28,021
10,646
213
polk county florida
Mar 20, 2018
#13
  • Mar 20, 2018
  • #13
He has new tank, but the opening could still be distorted enough to be a problem, I'd pull that tank and make sure all is good on top anyway but thats just me, I've only dropped a couple dozen tanks, I need more practice, but only with full tanks, empty ones are too easy.
HotFox
1,067
700
164
SE Michigan
Mar 20, 2018
#14
  • Mar 20, 2018
  • #14
Yes I get that he has a new tank but the that is being produced today this is very likely the problem. As I bet my factory tank is tougher then what he has.
Reactions: General karthief
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 20, 2018
#15
  • Mar 20, 2018
  • #15
First of all, pull the tank put and set it on the ground. If you are creative, come up with some caps and plugs for all the connections and openings except the vent. You are going to use it to carefully pressurize the tank. Get a small paint brush, some liquid dishwasher detergent and a plastic cup half full of water. Mix up some soap solution and apply it with the paint brush around all the openings in the tank. Carefully apply low pressure air -2-4 PSI to the vent line and watch for bubbles around the tank openings that you have capped or plugged. JB Weld does a great job on fixing fuel tanks once you know where the leak is.
General karthief
Mod Dude
Aug 25, 2016
28,021
10,646
213
polk county florida
Mar 20, 2018
#16
  • Mar 20, 2018
  • #16
Yea, your probably right, I've never dealt with a new tank.
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 7:38 AM
AlexM556
A
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
