new motor help
  • Thread starter Thread starter mustangderek22
  • Start date Start date Sep 28, 2006
M
mustangderek22
40
New Ringgold PA
Sep 28, 2006
  • Sep 28, 2006
New motor Help!!!!
I bought a gt-40x crate motor from ford racing...I have it installed...Every time I start the motor a blueish/white smoke comes out of both tailpipes?? why is this NEW motor doing this??...did i ruin something inside of it or what?? Anyone have any suggestions whu this is doing this?? Help!!! please
D
dwhiskie
183
  • Sep 29, 2006
Did you prime the oilpump before you started it the first time? White smoke is usually antifreeze. Does it smoke just at start up or all the time?
M
mustangderek22
40
New Ringgold PA
Sep 29, 2006
  • Sep 29, 2006
I don`t think i primed the oil pump before i ran it...the smoke only does it when it starts just for like 2 seconds and it smells like oil...def. not like antifreeze
dastang2
2,020
tx
Sep 29, 2006
  • Sep 29, 2006
priming the oil pump is essential to prevent a dry startup. the problem you describe sounds more like bad valve seals.
D
dwhiskie
183
  • Sep 30, 2006
I agree as well.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 30, 2006
  • Sep 30, 2006
Could be a bunch of things...
As Dastang2 indicated, priming a new engine is so important because the internals of this poor monster are about to go 0-1000 or more rpm with absolutely nothing to prevent surface to surface direct contact. Damage to bearing surfaces can result VERY quickly. Your issuse sounds more to be possible upper intake leak where coolant and or oil is making it's way in the combustion chamber, Another is rings have not seated and result is blowby...what type oil did you use to breakin the engine?...not a good time to use synthetics. Another good thought was brough up earlier, valve seal gone bad. Personally I'd want to do a compression and or leak down test to see if the motor can provide any clues to what's going on in there. Smoke at start is not normal on a healthy motor for the most part, but not an indication that it's going to fail.
M
mustangderek22
40
New Ringgold PA
Oct 2, 2006
  • Oct 2, 2006
when i first started running the new motor i did use synthetic but i changed it after someone told me about not using it so now i have 10w-30 in it...
DEFWISH
87
Wichita, Ks
Oct 2, 2006
  • Oct 2, 2006
sucks that a new crate motor would do that, blue smoke is oil, like valve guides/seals
P
postalbunny
118
Oct 3, 2006
  • Oct 3, 2006
If it's white or clear i've heard also that water condesates in the tailpipes/mufflers overnight and will burn off/blow out as steam on startup. If this only happens for a second or two it may be just that.
dastang2
2,020
tx
Oct 3, 2006
#10
  • Oct 3, 2006
  • #10
yeah but that's not blue smoke and it takes more than a few seconds to turn that water into steam. good suggestion though.
bt15
129
Oahu
Oct 3, 2006
#11
  • Oct 3, 2006
  • #11
Ford primes and runs those engines before they're ever delivered. They are compression and leak checked as new. They even have very minimal break-in requirements due to the fact that they are brand new engines built with brand new components in the Ford factory, just like all of their other line engines. It's possible there's a problem with the engine internals, but it's more likely one of the other systems, for example the fuel system. On my Cobra, about ever 3 or 4 months, I have a startup where I blow blueish / white smoke out the pipes for only a few seconds. There is a TSB out on it and it's simply due to the fact that there's too much fuel in the system during startup. Trust me, when the car was a couple of months old and it happened one morning, I almost died. I thought it was a major problem, but turns out it's completely normal. If you can get your sniffer in the smoke and discern if it's fuel smell (rich startup), burned oil smell, or even the antifreeze smell discussed elsewhere in this thread, then you can help narrow down your problem and determine whether or not it's a serious one. Don't get me wrong, even if it's "just" a rich startup, it shouldn't be chronic, and should be addressed. Good luck.
dastang2
2,020
tx
Oct 3, 2006
#12
  • Oct 3, 2006
  • #12
you can't tell if it has bad valve seals by just running a test. they could have ripped a valve seal when installing.
M
mustangderek22
40
New Ringgold PA
Oct 4, 2006
#13
  • Oct 4, 2006
  • #13
thanks for the help...I`m guess i`m gonna call somewhere to have it checked out and see whats wrong with it..
R
19 GT Window Motor Saga
  • Rcdgl
  • Oct 11, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 11, 2026
Rcdgl
R
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
J
Help - SCT Woes
  • James banks
  • Jan 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
