I just installed a new motor. The motor i installed is the crate ford engine GT-40X with the B303 camshaft (345hp). Me and my buddies set the timing and it idles rough and it seems to be in time, Is it idling rough because of the cam?
it drives good but if im driving slow in 1st gear at about 1/2-2rpm it surges but when u go above 2rpm it goes away...It doesn`t pop when you get on it...I have the power there when I get on the the throttle
CHECK FOR VACUUM LEAKS!!! This will cause the car to have a really big lope at idle and will still run fine. Go over all your vacuum connections as I can bet you have one that you did not reconnect or is cracked/broken somewhere.
