  • 1994 - 1995 Specific Tech
New Noise Vid!!!!
  • Thread starter Thread starter Guero
  • Start date Start date Jun 11, 2006
1 of 2 Next Last
Guero
2,148
Jun 11, 2006
  • Jun 11, 2006
http://media.putfile.com/pictures-95 Do you hear that squeaking noise??? Plus the same noise before. That sqeaking noise is new.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 11, 2006
  • Jun 11, 2006
yikes!!! that dosent sound good
F
fordtech28
312
Riverside Cali.
Jun 11, 2006
  • Jun 11, 2006
the squeking noise might be your belt but the knocking noise is not good
Guero
2,148
Jun 11, 2006
  • Jun 11, 2006
its not the belt, sounds like metal sliding on each other
urban96
3,464
Syracuse, NY
Jun 11, 2006
  • Jun 11, 2006
it could be a bad oil pump. definatly have someone who knows what their doing check it out
M
mackey
1,284
Beverly, Massachusetts
Jun 11, 2006
  • Jun 11, 2006
Sounds like a bad oilpump, and you just ruined a lifter. I'd check the block to see if there is any damage in the lifter holes.
Guero
2,148
Jun 11, 2006
  • Jun 11, 2006
no damage there
maximos
188
Columbus, OH
Jun 11, 2006
  • Jun 11, 2006
have your harmonic balancer checked
Guero
2,148
Jun 11, 2006
  • Jun 11, 2006
its brand new
mytight95
2,605
Dothan,Al
Jun 11, 2006
#10
  • Jun 11, 2006
  • #10
i'd be willing to bet when you have done the tears downs a couple times now, sooner or later you got debris in the oil pump, and it is gouged op on the inside losing pressure
jason
Guero
2,148
Jun 11, 2006
#11
  • Jun 11, 2006
  • #11
hell yeah my mom even took my umm... away cuz i was going crazy lol
Guero
2,148
Jun 11, 2006
#12
  • Jun 11, 2006
  • #12
im just tired of dealing with this pos, check out mt post in svt talk lol
slow50sally
66
Hawaii
Jun 12, 2006
#13
  • Jun 12, 2006
  • #13
**** my just started making that knocking noise hopefully I didn't do that much damage.
Zero Signal
2,633
Tucson, AZ
Jun 12, 2006
#14
  • Jun 12, 2006
  • #14
Did you try loosening the distributor and turning it alittle each way to see if it smooths out the roughness and knocking? As for the squeek, who knows what that could be.
maximos
188
Columbus, OH
Jun 12, 2006
#15
  • Jun 12, 2006
  • #15
have you checked the tensioner as a source of the squeaking?
vladasap
294
nyc, ny
Oct 15, 2006
#16
  • Oct 15, 2006
  • #16
I have the same problem but not the squealing
The banging is my tensioner - its pulled because I cant find the right belt after my smog delete so this one is on the tensioner really tight... the two metal pieces that are supposed to be touching eachother after you let the tensioner sit in its original state are about an 1/8" apart n due to the vibrations in the engines they hit eacother and make noise... check if that might be it if not sorry 4 the long post but i just couldnt describe it...
ps-how bad is it that my tensioner is so tense ... i tried the very next size belt n that one was already way too loose that it fell off but this one doesnt let the tensioner go back to its sriginal state... ????
T
tlee_20
48
Rogersville, TN
Oct 15, 2006
#17
  • Oct 15, 2006
  • #17
take the belt off and just crank the car for a second. if it quits, its probably the tensioner or the alternator.. but def. take the belt off and see if its still doing it.
Z
zZsKyZz
503
Oct 15, 2006
#18
  • Oct 15, 2006
  • #18
Take the belt off and try it, if it's that it's one of the pullies or tensioner.
It could also be the rotor hitting your distributer cap, mine usta do that for some odd reason.
As far as the knocking I get a feeling it's your harmonic balancer or something that threw the crankshaft outta place or off balance. Mine did the same exact thing when the rubber from inside the balancer tore apart.
T
tlee_20
48
Rogersville, TN
Oct 15, 2006
#19
  • Oct 15, 2006
  • #19
the knock doesnt sound deep in the motor to me. sounds more like bearings in the alternator or tensioner..
1TallMF
955
Montreal
Oct 17, 2006
#20
  • Oct 17, 2006
  • #20
Have you had any luck troubleshooting this yet?
1 of 2 Next Last
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
E
Noise near blower motor behind dash?
  • Ethereal_Zer0
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Ethereal_Zer0
E
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
