New Noise Vid!!!!
I have the same problem but not the squealing
The banging is my tensioner - its pulled because I cant find the right belt after my smog delete so this one is on the tensioner really tight... the two metal pieces that are supposed to be touching eachother after you let the tensioner sit in its original state are about an 1/8" apart n due to the vibrations in the engines they hit eacother and make noise... check if that might be it if not sorry 4 the long post but i just couldnt describe it...
ps-how bad is it that my tensioner is so tense ... i tried the very next size belt n that one was already way too loose that it fell off but this one doesnt let the tensioner go back to its sriginal state... ????
Take the belt off and try it, if it's that it's one of the pullies or tensioner.
It could also be the rotor hitting your distributer cap, mine usta do that for some odd reason.
As far as the knocking I get a feeling it's your harmonic balancer or something that threw the crankshaft outta place or off balance. Mine did the same exact thing when the rubber from inside the balancer tore apart.
