New personal best
  • Thread starter Thread starter NotQuik
  • Start date Start date Nov 20, 2008
NotQuik
5,158
29
88
Central Florida
Nov 20, 2008
  • Nov 20, 2008
Well I finally made it to the track after close to a year of not running and I was nice to be back yet rusty at driving. Anyway weather was low 50's high 40's but dew was setting and traction was limted for the most part especially as it got later in the evening which is no suprise for orlando spin world, plus an 1 1/2 hours for a cleanup didn't help either at one point. First pass was a cruddy 3500 launch and the car bogged to a 1.98 60' and I missed 2nd gear 3 times and went 14.1@103. Second pass was a better but spinning 1.922 60' launching at 5500 and dumping it and went 12.947@106.89. Car sat for a bit and dew set some more during this long clean up and on the 3rd pass it went 13.030@107.14 with a 1.920 60' got a tad of wheel spin into 2nd and a nice chirp into 3rd hence the better 60'/mph and slower et. Car got weighed after the passes were made last night and was 3630 with me (i'm 170) Mods are x-cal3 with mailorder tune, off road x-pipe, mac axle back, mt dr's, eibach prokit for what nothing that is worth. Car also has 3.31 gears and is a 5 speed...all else is stock down to the paper filter and shifter. Them times sound pretty decent for my mods?
i'll have some video's up this weekend.
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Nov 20, 2008
  • Nov 20, 2008
Sounds pretty good to me
I do believe there may be another tenth or so to be had there judging by your launch and some tire spin. What tire pressures were you running? Are you doing enough of a burnout to properly heat the tires? The guy that was helping me back in September was telling me that after the tires are properly heated they should still be very sticky by the time you get done with the pass and back to the staging lane or pit. It took me several times to get them to that point, but they did get that sticky! Also he said you know they're getting sticky when you're doing your burnout and the revs start dropping as the tires start wanting to grab.
NotQuik
5,158
29
88
Central Florida
Nov 20, 2008
  • Nov 20, 2008
They were set at 18 psi and I smoked them unlil they grabbed after letting off the brake. I hate the part after making a pass becaues the tires are like you said sticky so it kicks up rocks all over the place. I'll post the video and you can be the judge on wheel spin during the launch. I can't wait to do gears and maybe a CAI.
xtweakerx
411
Jupiter,FL
Nov 20, 2008
  • Nov 20, 2008
sick man! grats, im going this saturday to try to get into the 12's wish me luck!!
NotQuik
5,158
29
88
Central Florida
Nov 20, 2008
  • Nov 20, 2008
best of luck man, i don't think i'll be able to make it down that way unfortunately. Let me know how the new track is!
NotQuik
5,158
29
88
Central Florida
Nov 20, 2008
  • Nov 20, 2008
The first one 14.15@103
100_3468.flv]Pro5ohKid/Videos - Photobucket - Video and Image Hosting
Second Run...hard to see but 12.94@106.89
100_3470.flv]Pro5ohKid/Videos - Photobucket - Video and Image Hosting
Last but not least against the new challenger with the 6.1 hemi. 13.030@107 for me and 12.9@109 for him
1303at107.flv - Video - Photobucket - Video and Image Hosting
kooldawg6
Aug 31, 2006
1,679
Central VA
Nov 21, 2008
  • Nov 21, 2008
In the last video, are you driving around the water, backing up and then doing your burnout on dry track? With DRs, you should slowly roll through the water and start your burnout out just past the water and not stop until you see good clouds of white smoke in your mirrors.
Here is the pass where I was running against the guy that eventually helped me on my burnouts. His time as 12.7x while mine was a sad 13.3x, but hadn't even begun to get used to doing a real burnout yet He is running MT DRs and is pulling 1.5-1.6 60' times. Of course he has nearly 350 RWHP, but you can see by the length of his burnout that the tires do indeed hook very well! You will notice my tires don't really do much as this was one of my first runs and really had no idea on what to do until later in the day
YouTube - NVMC Drag Day 9-20-08 (11)
NotQuik
5,158
29
88
Central Florida
Nov 21, 2008
  • Nov 21, 2008
Our water box is basically a big puddle. From cars constantly driving through it they drag the water outside of the "box". I probably should have backed up more but I guess the reason I didn't was because after I backed up I kinda dry hopped it that's when I pulled forward thinking I was out of the water so I could do my burnout. I assume it wouldn't have spun at all if the tires were dry plus I couldn't see with the dew on the windows but I totally see what your saying and agree. I won't drive through the water box but I will back into it. The front tires will collect water with street radials on the front and you don't want that when you launch. Just like driving through the water box fast it'll kick up water in your wheel well and drip back on your tires while you stage. Do you think I should do my burnout longer though? I haven't ran on dr's much as i've mostly been on street tires nor do I race this car often since the 95 is for that or atleast my wife says.
Thank you for the pointers!
kooldawg6
Aug 31, 2006
1,679
Central VA
Nov 29, 2008
  • Nov 29, 2008
Sept was my first time with DRs and I was clueless as well. The guy helping me said the first few times it should be longer than you think you need. Kind of like showing off, but it works. After mine finally got broken in, I did about 5-8 second long burnouts. That along with 15 psi, my car was bogging down and not even wanting to spin (my first experience of the auto's limits) for what felt like the first 100'. Next season, I will have more power to help push me through that point!
J
2016 Mustang Gt Auto With 3:55 Rear Track Times...
  • jelsis
  • May 26, 2016
  • 2015 - 2023 (S550) Mustang -General/Talk
2K
2015 - 2023 (S550) Mustang -General/Talk Jun 5, 2016
echo7
New Best With The Turbo Car!
  • srtthis
  • Oct 22, 2013
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 22, 2013
A5literMan
M
How Bad Are Tires Hurtin Me?
  • MoneygrubbinCar
  • Jul 21, 2013
1996 - 2004 SN95 Mustang -General/Talk- Jul 22, 2013
MoneygrubbinCar
M
New Personal Best: 11.75 @ 120.81
  • sneaky98gt
  • Nov 25, 2012
1996 - 2004 SN95 Mustang -General/Talk- Jan 13, 2013
sneaky98gt
New Best Time in the 97GT (w/ video)
  • bhuff30
  • Oct 7, 2011
1996 - 2004 SN95 Mustang -General/Talk- Oct 10, 2011
fullrearview
F
