  • 1994 - 1995 Specific Tech
New Plugs
  • Thread starter Thread starter jwater7
  • Start date Start date Jun 18, 2005
J
jwater7
104
  • Jun 18, 2005
Hi all,
I'm having a bit of a problem with some pinging...so that "sparked" a few changes I want to make.
What type of plugs should I get? Maybe just some discussion on them if I want to keep my gas in the reg/plus range.
Thanks
91LX_5L
1,943
British Columbia
Jun 18, 2005
  • Jun 18, 2005
Its the timing not the plugs. Turn your timing down to 10* and you can run regular (87 octaine).
HISSIN50
34
129
Jun 18, 2005
  • Jun 18, 2005
If one suspects preignition, that is the time to consider going to a colder spark plug. Otherwise, i agree with above-advice. Back the timing down, use top end cleaner, etc.
Good luck.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 18, 2005
  • Jun 18, 2005
also might be a good idea to change the fuel filter
J
jwater7
104
  • Jun 18, 2005
Well, I've already done the fuel filter...but I've got larger injectors so the pressure is barely above minimum spec.
I've fiddled with the timing somewhat, but it works best around 10-12*. It's still pinging at that so that's why I'm looking into plugs/wires etc.
I thought pinging was pre-ignition. So if I put colder plugs in, it should "burn" rather than "explode" right? Is there a specific kind or type of "cold" plug that I should get? Are there any side effects if I use a colder plug?
Thanks.
HISSIN50
34
129
Jun 18, 2005
  • Jun 18, 2005
Thanks.
Preignition is not detonation. Preignition is where the intake charge is spontaneously combusted (glowing plug, red hot carbon deposits, etc). Detonation has to do with the spark timing in relation to the piston's position.
a colder plug will not get as hot between lighting off, but there is a larger chance of fouling the plug. If one runs Autolite 25's, an example of a plug one heat range colder is an Autolite 24.
You can try cleaning sensors, top end cleaner, and most importantly, back timing down some more.
Good luck.
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Autolite 3925 discontinued?
  • 387lx
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2026
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
