Well, I've already done the fuel filter...but I've got larger injectors so the pressure is barely above minimum spec.
I've fiddled with the timing somewhat, but it works best around 10-12*. It's still pinging at that so that's why I'm looking into plugs/wires etc.
I thought pinging was pre-ignition. So if I put colder plugs in, it should "burn" rather than "explode" right? Is there a specific kind or type of "cold" plug that I should get? Are there any side effects if I use a colder plug?
Thanks.
