StangBanger44 said:Does Advanced or Auto Zone sell a rebuild kit, not much look on their sites?
HammerG26 said:Thread Hijack - briefly - sorry :OT:
StangBanger - our Mustang <a href="http://georgiaregionalmustangclub.com/">Club</a> is going to the National Museum of Patriotism on Saturday and meeting Sunday. If you can - come by, there are some great people in the club and I am sure someone could help out.
Hammer
PS. I know Autozone sells carb rebuild kits.
StangBanger44 said:Ive been using the Gumout brand carb and choke cleaner. It has super jet pressure and when you spray it it blasts all of the varnish away. When i pulled it out this morning it looked brand new. Im going to let it soak a while longer and give it once over with some wires.
Yup, I leave the insulation on the wires I've used.John Z said:You posted while I was composing the last message. You are on the right track. Be very, no extremely, careful with using wire. The carb metal is very soft and a gouge in the wrong place could mean a new carb.
Im getting there! LOLEdbert said:The 289 is known to have small amounts of torque, the short stroke and relatively large bore cause that along with the small displacement. You put a low torque/high RPM reciprocating assembly in front of a 2.70-2.80 gear and it WILL be sluggish off the line. When the RPMs get over 3K do you still feel the sluggishness? What other car are you comparing the sluggishness to?
A stock 289 and the stock C4 should shred a tire (one only with open diff) if you try to burn it.
If you know your brakes are dragging I'd definitely fix that before driving it much.
StangBanger44 said:The brakes are next in line, the only thing i have to compare to is my 93 GT. Gonna run a compression check this week.
but yes, when mine was all stock with a 3 speed, i ran it in the quarter mile and got a 17.3 but now, its down to 13.0 StangBanger44 said:Yeah that old gas had did a number on the plugs. Carb rebuild went easy and and the idle changed as soon as i put it back on. As soon as i cleaned the plugs the vibration went a way. I am not expecting much out of the motor for now just to cruise around in. Hopefully a new 4 barrel and intake will wake it up a little along with some 3.55 gearing or even 3.80.
