New Track Times!
  • Thread starter Thread starter $uperstang
  • Start date Start date Oct 22, 2007
1 of 2 Next Last
$uperstang
476
Detroit, MI
Oct 22, 2007
  • Oct 22, 2007
Put the Draglites on and an FRPP driveshaft:
60ft - 1.71
1/8 - 7.7@88mph
12.21@110mph
millhouse
1,985
Simpsonville, SC
Oct 22, 2007
  • Oct 22, 2007
Congrats!
I'm envious of your 60' for sure!
BTW, was that at Milan or Stanton?
$uperstang
476
Detroit, MI
Oct 22, 2007
  • Oct 22, 2007
millhouse said:
Congrats!
Thanks millhouse it was at Milan.
I need to figure out a way to get my 60ft down to 1.6 and see if she will run a 11.9
millhouse
1,985
Simpsonville, SC
Oct 22, 2007
  • Oct 22, 2007
Ahh yes, those elusive 11's!
Wallzy
128
Orlando, FL
Oct 22, 2007
  • Oct 22, 2007
Real Nice Times, hel-uv-a dig out of the hole.
Cheers
Walz
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Oct 22, 2007
  • Oct 22, 2007
get a sticky tire and floor it off the line at 6k
$uperstang
476
Detroit, MI
Oct 22, 2007
  • Oct 22, 2007
LMAO 6K out of the hole I wish, Would be very hard with an AOD I have a 3200 stall and launch at 1K rpms I have MT drag radials, I know she'll make it on slicks but I want to do it the hard way on drag radials!
ninety15.0
1,336
  • Oct 23, 2007
Good short times for that setup though..congrats man
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 23, 2007
  • Oct 23, 2007
get a t5 or a higher stall. with my t5 i leave at 6k and it launches hard.
but for your AOD pulling those 60's launching at 1k thats really good. if you get a nice launch at higher rpm it will pick up alot
NKau
1,346
Jefferson, WI
Oct 23, 2007
#10
  • Oct 23, 2007
  • #10
Very nice times. What's done to the motor outside of the stroker kit?
At his power level, he's not going to gain a whole lot in the 60' department; could cut some 1.6's with a manual tranny which equates to a .2 second difference in his E.T.; don't think it's really worth it IMO.
MrXCESSIVESPEED
Maryland
Oct 24, 2007
#11
  • Oct 24, 2007
  • #11
Congrats!
I really dont think you'd pick up as much as you think going from the MT DR to a slick though....those DRs work pretty well.
blackened88lx
Connecticut
Oct 24, 2007
#12
  • Oct 24, 2007
  • #12
Nice times. What's the setup? Why are you launching at 1k with a 3200 stall? Is it spinning if you launch any higher? What do you run for tire pressure? Pull your front sway bar. Battery relocation. You'll get it down there!
pistonhead351
flim hunter
May 1, 2005
75
#13
  • Oct 24, 2007
  • #13
that allows for the converter to flash. if he brought it up to the stall speed it would probably leave slower. all converters are different though.
$uperstang
476
Detroit, MI
Oct 24, 2007
#14
  • Oct 24, 2007
  • #14
Yes this is oh so very true. The conveter flashes when I launch her off idle. I can stall it to about 2800-3000 but it does worse because she will bog.
$uperstang
476
Detroit, MI
Oct 24, 2007
#15
  • Oct 24, 2007
  • #15
Tire pressure was set at 15psi. I had it at 16 on the first run and it went 12.35@107mph. Then I did three more runs at 15psi and ALL three passes were 12.2@110, maybe I should have tried 14psi?
The combo is a 325 stroker at 9.8:1
AFR185 heads out of the box
TFS 1 cam
3.5" AFM powerpipe
70mmTB and 77mm pro-m with 24lb inj. SCT dyno tuned
Cobra intake with fully ported lower and matched to the heads
13/4 long tubes to 2.5", Prochamber and flowmasters.
I have no AC, no smog, no swaybar, and dual electric fans. I think I may re-locate the battery though.
$uperstang
476
Detroit, MI
Oct 24, 2007
#16
  • Oct 24, 2007
  • #16
Thanks for the compliments guys I am so close to 11s it is driving me crazy
$uperstang
476
Detroit, MI
Oct 24, 2007
#17
  • Oct 24, 2007
  • #17
What do you guys think about getting her re-tuned on race gas 110? Do you think it will be enough?
millhouse
1,985
Simpsonville, SC
Oct 24, 2007
#18
  • Oct 24, 2007
  • #18
Only if you like going slower.
$uperstang
476
Detroit, MI
Oct 24, 2007
#19
  • Oct 24, 2007
  • #19
True! Dumb idea
I just talked to Bill on Hardcore 5.0 and his recommendation is to send my converter back to loosen her up to 4200 stall. Now that I never thought of and he said it should get me there and also recommended an electric Meizer waterpump
millhouse
1,985
Simpsonville, SC
Oct 24, 2007
#20
  • Oct 24, 2007
  • #20
$uperstang said:
True! Dumb idea
It sound's like your on the right track.
I'm not sold on the electric water pumps though. I'd be concerned with their longevity...and their taxing of the electrical system.
1 of 2 Next Last
F
Leak from tail shaft after 2 new seals
  • Fox123
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
JD1964
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Aod to t5 swap will it live?
  • 87slow.0
  • Nov 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2024
87slow.0
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
