Newbe
  • Thread starter Thread starter turbinesurgeon
  • Start date Start date Apr 23, 2007
T
turbinesurgeon
24
Phoenix, AZ
Apr 23, 2007
  • Apr 23, 2007
I am new to Fords, I just bought a 72 fastback without an engine and I have several question.
1. I just bought a 302 that had a manual transmission and I will be using a FMX automatic. Since the motor is balanced with a manual flywheel should I be worried about the motor being balanced properly?
2. Is there any decent overhaul kits for the FMX?
Thanks
T
tylerrocks
514
Big Spring, TX
Apr 23, 2007
  • Apr 23, 2007
Not too familiar with autos, but I'm pretty sure your gonna need to ditch the flywheel and get a flexplate.
Max Power
1,774
St Paul
Apr 23, 2007
  • Apr 23, 2007
Well, of course you are going to have to ditch the flywheel and get a flexplate. If you bring your old flywheel and your new flexplate into a competant machine shop, they can match it up for you.
FMX stock rebuild kits are available, and you can get a shift kit from B&M or Trans-go. Stall converters are rare as hens teeth, and high performance internals are not made, for the most part.
Edbert
3,548
32
109
Austin TX
Apr 23, 2007
  • Apr 23, 2007
The FMX has a poor reputation, they are quite strong but also quite heavy, generally not a good choice for a performance buildup. All early fords were 28oz imbalance, FoMoCo switched to a different design later (I'm thinking 1981 but better verify the date), so as long as you are using all old or all new style SBF parts you should be okay. It gets a little more complicated when you mix them up. For example my AOD came with a different sized (number of teeth) flexplate than the C4 my car had. The AOD flexplate was 50oz and my crank was 28oz, so I bought an AOD flexplate with latemodel teeth and early model balance.
Clear as mud?
HistoricMustang
2,359
Confederate States of America
Apr 23, 2007
  • Apr 23, 2007
delete
HistoricMustang
T
turbinesurgeon
24
Phoenix, AZ
Apr 23, 2007
  • Apr 23, 2007
Thanks for the help guys, I do have a flexplate that came out of the original 302 and the motor has the early style original dampner so I guess I can just bolt the flexplate on and go.
Edbert
3,548
32
109
Austin TX
Apr 24, 2007
  • Apr 24, 2007
I've found that using the word "guess" like you just did can often lead to regret.
The front dampner is a good hint, you're sure it is the right one. You still have to be reasonably sure that it is the correct damper for the crank...in other words...was the engine in running condition with the parts you have now?
The flexplate may have come from a C4, are you sure the bolt pattern is the same from a C-series to an FMX? If iit came from the FMX you're good to go.
T
turbinesurgeon
24
Phoenix, AZ
Apr 24, 2007
  • Apr 24, 2007
The flexplate came off of the original 302 that had the FMX attached to it so I am positive this flexplate works with a FMX. The new motor I have had a 3spd attached so I was just wondering if the balancers are the same. Both engines are 1972. I was just wondering since this motor was balanced with a flywheel would there be any harm converting it to an auto?
MustangMatt1966
1,004
Orlando Fl.
Apr 24, 2007
  • Apr 24, 2007
Why not just leave it a manual???? they are more fun anyways
jadesville
the polarbear conservation corps protects a polarb
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Apr 24, 2007
#10
  • Apr 24, 2007
  • #10
Just to throw in my 2 cents, I would be looking for a C4 instead of a FMX, they have a weight difference of ~65 lbs, and the C4 parts are more readily available. To answer your question, no, you just need to find the same balance flexplate and Edbert what said, double check to make sure your dampner is the correct balance for the engine.
Edbert
3,548
32
109
Austin TX
Apr 24, 2007
#11
  • Apr 24, 2007
  • #11
No, if they were both 28oz then you're golden.
T
turbinesurgeon
24
Phoenix, AZ
Apr 24, 2007
#12
  • Apr 24, 2007
  • #12
I couldn't agree more, however the car is an automatic so I am not going to go through the hassle of converting it to a manual.
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
