Newbie - Looking for pointers
kmraj
Greetings,
My wife is going to get me a 65 FB Project Car for my birthday. This means I have a horizon of between and 0 and 18 months to find the right car.
From what I have read here, other sites, and neighbors, I am getting these basic points:
1. Make sure the rust isn't compromising the structure (floor pans, hinges, quarter panels)
2. I am looking for a car that is going to be restored over 10 years, but I know nothing about welding so I need to make sure the rust is surface level and can be ground out and not a cut and remold (as in it needs to go to a shop to get fixed and not in my simple garage environment).
3. I want a stick and not an auto
4. Desiring a K engine is a pipe-dream so don't look for it. If the engine runs I would like it to be a 289 and not the 267, but I am not averse to a non-running engine (hey I have time on my side!!)
5. I understand cards and have friends that are interested in helping, so my hardest part will be parts.
6. I am in CA. All the "dealers" stress that you want a car from the "U" outside of the northeast if you want to ensure you don't get a "rust bucket" but in reality, location doesn't dictate where it started. DREAM - Finding an R manufacturing code as Fremont is near where I live.
7. I know there is more that I don't know than I do know.
What I seek, the groups collective knowledge in shepherding me through the finding phase. Where should I look for the car (there is more than just the internet), what should I be expecting to bay for a car that I dont want to drive home, that I could road trip if I had a support car behind me. NO LOOKING FOR A SHOW CAR.
All help is greatly appreciated and I will have a blog going over on the blog site as I get closer to finding the car!
Thanks in advance
You probably won't buy the first car you see, don't let excitement get the best of you. Buy the car in the best condition you can afford, it will put you leaps ahead. I don't weld either so my main focus was frame rails, floor pan, trunk, cowl area. I eventually found a coupe after looking at >6 coupes and convertibles. The conversion from auto to stick isn't that involved from what I've read> pedals, Z bar and working around the exh. if headers. There are lots of upgrades to make it a nicer stick like 5sp. (OD is awesome), cable or hyd. activation vs. the Zbar manual linkage, etc.
I looked in the cowl with a flash light to check for heavy rust, this part does not come apart or off the car w/o drilling out many (>50?) welds and is an $$ fix. I layed on the ground and stuck my findgers into every opening under the floor pan I could find to see if I could dig out any rust scale, I did on the first 6 easily and passed on them. Open the trunk, look around where the gas tank mounts for rust as this is where water sits when the trunk seal leaks.
Unless you're doing a concours resto ask here or another forum what your options are before replacing anything, for example the '65-'68 16 gal. gas tank can be replaced with the '70 22 gal. tank with a little tweaking of the filler neck, costs no more than the smaller tank and only raises the top of the tank 1"-2" in the trunk. Without a lot of research or question asking you could waste money on replacements.
I would join your local Mustang club and go to a meeting, meet a member with a '65 fastback and crawl over the car with them, where to look, what to look for, someone may also be selling or know someone selling...car shows and cruise ins are a good place to meet owners also.
Jon
