nitrous help
antyates
12
what regulator can i use to get 8psi from a efi pump (45psi)
Got rid of my carb for a fuel injector system (looks like a carb) but i still want to use my nx nitrous plate system, need to know what to do to get fuel to nitrous system.
Thanks
DrMaxit
139
Augsta GA
Yikes um, so far as the regulator? Im not sure id go that route but you could probably find one. You could buy a drop in pump that would run around there you could regulate safer.
So far as getting the fuel to the nitrous system, you could run a T in your line to branch off. Zex recommends this on their site for their system.
Just some ideas.
--Chuck
antyates
12
Thats what i got is a t, but still a problem, I still have efi pressure. and i need to regulate that down to about 8 psi for the nitous fuel solenoid.
Can a holley (cheap) fuel reg. handle 45psi and regulate to 8psi?
Thanks
