nitrous question
  • Thread starter Thread starter skiwesser
  • Start date Start date Oct 20, 2006
skiwesser
35
  • Oct 20, 2006
With 60 shot runs great no sputter or anything, tried to go to 125 shot 42 psi fuel pressure and it came on STRONG but started sputtering at high rpm, not detonation or backfiring , but like pop,pop,pop, timing was at 11* went to 9* same thing, in fact i think it backfired through the top end (no damage), tried 90 shot same thing ??
I have a 190 lph pump, crane Hi-6 Ing. box, wet system with 1 nozzle at T.B.
Plugs looked ok def not rich, should I jack up the fuel presssure??
Help I'm supposed to go to strip on Sun.!!
skiwesser
35
  • Oct 20, 2006
Could my plugs be too hot?
I'm running autolite 3923's as per AFR's recommended starting point, I know nothing about heat ranges of plugs but these are long shank so autolite 24's I was running won't work.
I picked up some NGK - 8's?? dude said it was a pretty cold plug?
BTW I figure compression at 10-1, 10.25-1
M
Marlboro_Man
437
Houston, TX
Oct 21, 2006
  • Oct 21, 2006
What did you set the gap on the plugs to???
bubba-dough
1,044
Indiana
Oct 21, 2006
  • Oct 21, 2006
Yes what is the plug gap? Also just to dbl check, did you put the right fuel jet in place?
RYC CUKR
1,437
Orlando
Oct 21, 2006
  • Oct 21, 2006
As others have said check the plug gap. I run around .035-.038 with nitrous. It sounds like the increased cylinder pressures are blowing the spark out.
skiwesser
35
  • Oct 30, 2006
#8 plug had gotten lose, but still ran bad at track!!
9.00 all motor
8.72 60 shot of gas 1/8mi
Pitiful for my combo I've got to find the bug in this motor!!
stangjunkie
381
  • Oct 31, 2006
speaking of slow combos....
RYC CUKR am i the only one that thinks your times are slow for your combo?? i've seen this a while back and often just never said anything
  • dan50
  • Jul 18, 2026
dan50
J
89 2.3 LX running rich, hesitation on acceleration, high and hanging idle Help!
  • jpstucky
  • Jun 13, 2023
  • 2.3L (N/A & Turbo) Tech
3K
2.3L (N/A & Turbo) Tech Jun 15, 2023
jpstucky
J
Progress Thread Still in need of nitrous help!!
  • skiwesser11
  • Oct 15, 2020
2K
Fox 5.0 Mustang Tech Nov 11, 2020
skiwesser11
W
no start after distributor came apart inside
  • White-fox
  • May 8, 2022
4K
Fox 5.0 Mustang Tech May 23, 2022
limp
Electrical Cylinder 4 Misfire
  • paddyrk
  • Oct 11, 2021
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Oct 12, 2021
paddyrk
