No blinkers
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date Apr 21, 2010
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 21, 2010
  • Apr 21, 2010
Alright i have gone through everything and my ****in blinkers dont work, i have checked the hazard switch, multi function switch and even the ignition switch, both blinker relays and still nada, my hazards work but my blinkers dont, windshield wipers work, hi beams work, and all cluster lights work, wtf could it be
Y
y0ukantride
36
Indianapolis
Apr 21, 2010
  • Apr 21, 2010
No offense just going through order as my brain processes ... Fuse, bulb, pull the turn signal out and check for continuity with the turn signal blinking, check ground wires, check continuity at the switch in the colomn.. hope this helps
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 21, 2010
  • Apr 21, 2010
all have been preformed, cant test continuity with the blinkers blinking if they dont blink, bulbs are all brand new and i know they work because of the hazards working
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 22, 2010
  • Apr 22, 2010
Are you aware that your car has two flashers, one for the hazards and one for the turn signals? The one for the signals is on the opposite (back) side of the fuse panel from the hazard flasher. Reach up behind the fuse panel and you'll be able to feel it. I've had more than one person have that be their problem.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 22, 2010
  • Apr 22, 2010
yep
R
RatStang
544
  • Apr 22, 2010
Shaolin --
Didn't you have a thread about electrical gremlins a week ago or so? I remember vaguely, something about that. If so... and now this new symptom is being added to the mix, I'll tell ya that I still think you have a stray ground somewhere behind your dash. The more you add these kinds of symptoms, the more I'm convinved that, that is where your problems are.
Dig into that mofo and look hard at ALL your underdash grounds. Reseat them all, cut and resolder questionable wiring and replace any splices you see.
Somewhere, you're getting stray voltage and/or not getting the grounds that you need for everything to work correctly.
I've been in this situation where similar problems occured and seemed totally unrelated. In my instance it was a single broken ground wire that ran from one of the dash harnesses to the dash chasis next to the radio. It was so very strange that all these gremlins I'd been banging my head against came down to this silly, skinny, ground wire.
Tanus
847
A to the Z
Apr 22, 2010
  • Apr 22, 2010
I had the same problem, it was the ignition switch, I see you checked it, but Id just replace it if i were you, only costs 10 bucks, that also fixed a bunch of little problems I was having too.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 22, 2010
  • Apr 22, 2010
DontGivaRatz said:
Shaolin --
i did, turned out to be the blinker asembly itself, once replaced everything started working
as far as the bold quote, this is a new build, bare chassis, i did this before it even went into the car, all grounds are attached and everything BUT the blinkers work now
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 25, 2010
  • Apr 25, 2010
bueller?, any got a clue where to start looking next
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Apr 27, 2010
#10
  • Apr 27, 2010
  • #10
anyone?
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
