No Bright light's
gungfusemaj
211
Bradenton Fl
Ok low beams work High Beams do not ....when I falsh over I get no lights at all just low beams . My blue cluster light does not come on ethier, I've replace the bulbs etc. Need help My fogs are completly disconnected.
Over time the plastic shells that hold the wiring connector pins will overheat. If the multifunction switch has failed, odds are that the plastic connector shell has some heat damage too.
A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-89 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
See http://www.corral.net/tech/maintenance/foglights.html for the foglight fix.
