NO FUEL PRESS Car wont start
94gt_vert_proch
10
Well i had my car running today with my new 60lb injectors and all of the sudden it started to run real bad then stalled. When it was running bad the check engine light came on so i ran the codes and got code 542 wich is Fuel Pump secondary circuit fault. started the car back up it ran and smelled like raw fuel really bad so i shut it off and now no fuel press at all. It will jump to about 20psi when the pumps turn on then drop to 0 right away. Both pumps on my car are kicking on but nothing. I have checked fuses but all seem to be good. I cleared codes and tryed to scan again but i get nothing. Can the fuel press regulator be shot? the pump bad relay? or maybe the fuel filter is cloged.
If anyone can help please let my know this is driving me crazy
Thanks alot.
Just a random question, but are you running high or low impedence injectors? The 542 can sometimes be a ghost code if you have a hiccup (almost stalled a manual car) and the engine fires back up immediately before the car realizes what happened.
Since it is able to build some pressure, one might guess the electrical side is functional to some affect. The variable is not knowing the deal with the second pump. Ergo:
In case you wanna do some FP relay testing, check the second bolded section here.
Matt is spot-on about 542 possibly being a ghost code. How is/are the fuel pumps wired up?
Since Injectors are a new variable, are you sure they are not seeping?
Good luck.
