no headlights
  • Thread starter Thread starter Mafia Mustang
  • Start date Start date Jul 14, 2007
M
Mafia Mustang
111
Arizona
Jul 14, 2007
  • Jul 14, 2007
Hey peeps I got no head lights.My running lights come on and my brights work but not the headlights or the foglights wtf lol.
93 LX
3,081
Norwalk, CA.
Jul 14, 2007
  • Jul 14, 2007
bad headlight switch
maxine-70
20+ Year Stangneter
Mar 27, 2003
273
louisville, ky
Jul 15, 2007
  • Jul 15, 2007
i had that issue on an 88 turbocoupe years ago. i replaced everything imaginable. then i called the dealer and they told me it was a recall issue and the wiring harness in the steering column had to be replaced and was a fire hazzard unless replaced by the dealer under the recall.
i dont know if its still able to be taken to a dealer under recall or not. or if thats even your issue.
i started with the headlight switch. that wasnt it. i then went to the hi/low switch on the column. that wasnt it. it drove me nuts. the headlights would work only on high beam and only if i HELD the switch all the way into the high beam mode.
the recall was a general recall for late 80's fords
93 LX
3,081
Norwalk, CA.
Jul 15, 2007
  • Jul 15, 2007
thats the pass mode when you pull the high beam switch back and hold it. Only the high beams turn on without running lights. Start at the obvious place 1st. Verify that the low beams are in good shape and the light. Check the connecto wiring at the head light then check the headlight switch using a test light or volt meter.
Allen
daviszx3
42
maryland
Jul 15, 2007
  • Jul 15, 2007
you probably have a bad multi-function switch mine went bad on my 89 gt was doin the same thing your talking about
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
