No oil pressure
  • Thread starter Thread starter deathstrike
  • Start date Start date Jul 18, 2007
1 of 2 Next Last
D
deathstrike
21
Alabama
Jul 18, 2007
  • Jul 18, 2007
Ok new here and this is somewhat long story…
I am going to use Guy1 and Guy2 in the story. The motor was rebuilt 2.5 years ago but only driven for 5 months. Guy1 rebuild the motor and put a turbo on it. Guy1 drives it for 5 months and kept having tranny problems with it. Guy1 did not have time to fix it because he got acceptance to the State Trooper Academy and sold it to Guy2. Guy2 never install it or ran it, it just sat there for 2 years. Guy2 decide to sell it so I bought it from him. I got the motor and the only problems I am having is no oil pressure at idle and at 2000 rpms I am only get 5 psi. Every time I hit the gas, it goes up slowly. I am using a mechanical oil pressure gauge and still no oil pressure. There is no noise or knocking coming from the engine. It starts up on the first turn. Some of my friends are telling it is the oil pump and some think it is the bearing but I primed it before starting it and getting oil up in through the motor. Only thing I did not check if I was getting oil up to the rockers. I need HELP!!!
new stuff I added was:
3000 stall
Trick flow Stage 1 Cam
Comp Cam push rods
Comp Cam lifters
Sevan
558
IL
Jul 18, 2007
  • Jul 18, 2007
oil pump can be cloged or not working correctly. it can also be the oil sensor thats located on the stock pan on the driver side, its screwed into the pan. under accelration the oil gauge will move so thats normal. have you done a search regarding this same issuse someone else might have had?
D
deathstrike
21
Alabama
Jul 18, 2007
  • Jul 18, 2007
I search every where on this issue and so far everyone is talking about the oil pump or the bearings.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jul 18, 2007
  • Jul 18, 2007
If you truly have a good mechanical gauge and its only get up to 5 psi I'd stop running the engine. The best thing to do would be to pull the oil pan and check everything. If you want to make a quick check, pull the distributor and see if the oil pump drive shaft is twisted or broken. A piece of debris could have gotten in the oil pump and locked it up. Or at least change the oil and check for debris or bearing material in it. You will see gold looking sparkle in the oil if you have started losing your bearings. You will definately want to check bearings though if the engine has been ran for an extended period of time like this.
D
deathstrike
21
Alabama
Jul 18, 2007
  • Jul 18, 2007
I haven't drove it yet because I just put the motor in the car. I have just started it to test things out before I drove it.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jul 18, 2007
  • Jul 18, 2007
test your OPS
D
deathstrike
21
Alabama
Jul 19, 2007
  • Jul 19, 2007
I'm new this... What is OPS? You mean Oil Pressure Sensor.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 19, 2007
  • Jul 19, 2007
Are you sure someone didn't leave a rag in the oil pan and it is covering the pickup?
If the pickup tube is damaged or loose at the pump, you could have a good pump and no pressure.
bullitstang1313
713
Jul 19, 2007
  • Jul 19, 2007
He is using a mechanical gauge and only gets up to 5 psi, this is a problem. Either the mechanical gauge is broken or he is not getting oil pressure. If you aren't getting oil pressure then there is something wrong. The only way to find out is to start taking things apart.
D
deathstrike
21
Alabama
Jul 19, 2007
#10
  • Jul 19, 2007
  • #10
its a brand new oil pump pressure gauge
bentley429
Banned
Nov 25, 2004
528
Connecticut
Jul 19, 2007
#11
  • Jul 19, 2007
  • #11
Then your going to have to pull the pan to really check things out. I would replace the oil pump reguardless of what it looks like and pull acouple main bearing caps. If all looks good throw it back together and start her up. Put a ARP oil pump driveshaft in too.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Jul 19, 2007
#12
  • Jul 19, 2007
  • #12
Actually, where do you have the gauge hooked up to? The log on the side of the engine? If so try pulling that off and possibly that is clogged somehow, its worth a shot even though thats prob not the verdict.
1988foxbodylx
#13
  • Jul 19, 2007
  • #13
take your valve cover off and start your motor to see if your getting oil up there
D
deathstrike
21
Alabama
Jul 20, 2007
#14
  • Jul 20, 2007
  • #14
I'm going to do that on Sunday when I get back in town.
D
deathstrike
21
Alabama
Jul 23, 2007
#15
  • Jul 23, 2007
  • #15
No debris or gold sparkle in the oil. So I guess it's the oil pump. I bought a new oil pump for it.
BYRDPE
1,556
Memphis,Tn.
Jul 23, 2007
#16
  • Jul 23, 2007
  • #16
Did you pull the VC to see if it was getting oil to the rockers?
D
deathstrike
21
Alabama
Jul 23, 2007
#17
  • Jul 23, 2007
  • #17
That's the only thing I haven't did yet.
D
deathstrike
21
Alabama
Jul 30, 2007
#18
  • Jul 30, 2007
  • #18
Ok, I put in a new oil pump and took of the VC to check to see if I get any oil to the rockers and no oil. Also still no oil pressure.
W
Wade95
TarponSprings,FL
Jul 30, 2007
#19
  • Jul 30, 2007
  • #19
I sure hope you haven't damaged the engine. Take that puppy back out of the car, flip her over and start looking at things. Good luck!
troyGT03
278
too close to memphis,tn
Jul 30, 2007
#20
  • Jul 30, 2007
  • #20
what oil filter is on the car? fram????
1 of 2 Next Last
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
