no power...
aaros
114
top that is. i got sick of refilling my pump on my vert so i went to dissconect the rams and found that you cant get to the top of the ram from the side. i learn this after i done broke a the trim around my seat belt. top up there is a hitch pin that holds a pin through the frame of the top, pull the pins and then push the ram back down as far as you can. its about as retro as i plan on takeing my car. will i need to worry about the wind catching the top now that the rams are dissconected?
