  • SN95 4.6L Mustang Tech
No power
  • Thread starter Thread starter mirage86
  • Start date Start date Oct 12, 2009
mirage86
78
  • Oct 12, 2009
I've got an 03 GT 5 spd. Sotck with 84000 miles. Vehicle runs fine except when u go to get on it. When u put the gas to it, rpms climb up but the car does get up and go like it used to. I thought the clutch was slipping and put a new one in. But it does the same thing. Under a load, it doesnt cut out like a missing plug, stopped up exhaust or starving for fuel. R the stangs prone to anything that would cause this? I dont wanna start throwing stuff at it.
squeak93
2,348
417
164
Joplin, Missouri
Oct 12, 2009
  • Oct 12, 2009
Does the car have any codes?
More importantly, have you verified that its lost power? Like your track times have slipped badly or something like that? Over time you get used to things and it may feel like its slowing down when in fact it runs like it always did but your instead just used to it and maybe bored.
mirage86
78
  • Oct 12, 2009
I c what ur saying, but i dont go to the track. Im basing this on driving. For instance when passing someone, 2nd or 3rd would be my gear of choice with the type of driving that i do. The car would get on up and move around. Not now. CEL was on before I did the clutch, went off cuz I had the battery undone. I dont remember the number, but it pertained to egr flow detected. Most vehicles I work on with a stuck egr usually wont idle for crap. That could be it though. My gas milage has gone to crap though.
squeak93
2,348
417
164
Joplin, Missouri
Oct 12, 2009
  • Oct 12, 2009
If the egr is malfunctioning, it can cause all sorts of issues. The light should come back after enough drive cycles.
When it does, pull the code and check back.
trinity_gt
3,125
81
99
Canada
Oct 12, 2009
  • Oct 12, 2009
Can you elaborate on the bolded part more? Does the engine RPM flare in response to throttle input, so much so that you thought it was a bad clutch, had it replaced and after that it's still doing the same thing?
mirage86
78
  • Oct 12, 2009
I mean that the rpm's go up in response to increased throttle. I replaced the clutch because I thought it was slipping due to the vehicle not speeding up in accordance with throttle that was being given. Never at anypoint do I observe RPM flare like it's slipping. Example. It's raining here today. I pulled out on the raod in first and gassed it. Tires would not break a spin. The car doesnt spit and sputter. Speed slowly eases up.
C
cronin49
Banned
Aug 12, 2003
432
SC
Oct 13, 2009
  • Oct 13, 2009
What he said.
I have one of those accelerometer units and recently I was fooling around with it. My car hit 100mph in 9.55 seconds, but I have been driving it with the blower on it for so long it doesn't seem that fast anymore. But it be.
Mileshigh
25
Raleigh
Oct 13, 2009
  • Oct 13, 2009
Have you replaced the fuel filter lately? Could be reducing the flow to the engine at wot....you could have got some bad gas at some point..when was the last time the spark plugs were changed?
Brute03
232
  • Oct 13, 2009
i doubt its all in his head if his gas mileage took a hit. when was the car last serviced?
mirage86
78
#10
  • Oct 13, 2009
  • #10
Changed the fuel filter yesterday. No change. The plugs are original. I dont think that it's an ignition issue. Im leaning towards the cats possibly starting to stop up. Considering that if I just ease in to it, I have no problem getting speed up. Its just if u hammer on it and really put a load on it. At this point that's all that makes sense.
If I went with an off road h-pipe or x-pipe would it really monkey with the pre cat o2 sensors? I know it would the post cat, but I assume they work like gm and do not make any changes. They strictly monitor the cat (post 02s).
mirage86
78
#11
  • Oct 15, 2009
  • #11
The DTC is P1406. Something abt EGR restricted. I dont remember the exact wording. I'm still leaning towards cat stopping up. O/R pipe will be here tomorrow.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 15, 2009
#12
  • Oct 15, 2009
  • #12
Check EGR system and DPFE sensor
The P1406 EGR code is one that I am very familiar with. This DTC basically means that the EGR flow is not as expected.
This DTC has several causes.
1. Carbon build up in the throttle body that blocks/restricts the EGR flow.
2. A problem with the EGR valve itself. The valve usually rots out from the corrosive exhaust gases.
3. Bad differential pressure feedback sensor (DPFE). The EGR flow is actually OK but the sensor is giving a false reading.
4. leaky hoses connecting the DPFE to the EGR tube.
The worst thing about this problem is that the DPFE is bad about half the time. This means that you usually have to rule out a blockage in the EGR system itself. When you are sure that the EGR system is clean (usually after the EGR valve has been replaced), you replace the DPFE which solves the problem.
The DPFE throws false DTC’s so much of the time, Ford redesigned the sensor to adjust the allowable range of the signal return. The all Metal DPFE is the worst. The plastic one is not as bad.
If the code is for insufficient EGR flow, this will only affect emissions. If the code is for excessive EGR flow, this will affect drivability.
IMO, if this is the ONLY DTC you are getting, clogged cats is not the cause.
Recommend the first thing is to inspect the hoses leading to/from the DPFE. They are hard to see and are subject to hot exhaust gases. They dry up and leak. This upsets the flow to the DPFE and allows exhaust gases to leak. Because the hoses are so close to the firewall, they are difficult to get to.
If the hoses are fine, next thing is a crap shoot. As stated before, the DPFE sensor is bad about as often as there is a real problem with the EGR system itself. At 84k miles, this is not high enough where I would definitely say to start with the EGR valve.
If you replace the DPFE, go to Ford and get the revised one. Also, replace the hoses. You will hate me while doing the job. But in the end, it will stay fixed longer.
Good luck. This problem has kick my tail more than once.
mirage86
78
#13
  • Oct 15, 2009
  • #13
But would 1406 cause a drivability issue? My experience with egr's is that the only monkey with idle.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 15, 2009
#14
  • Oct 15, 2009
  • #14
Depends. The DTC is because the measured EGR flow is not as expected. Usually this means not enough EGR flow. But it could mean too much EGR.
Bottom line is, too little EGR flow will NOT affect drivability. It will cause a "check engine".
Too much EGR will affect drivability. How much depends on the conditions at the time (idle/power/how much excessive flow there is).
If the EGR flow is way out of wack, it could create all kinds of problems such as what you are experiencing. However, for it to be that far out of wack, one would expect the EGR valve to be rotted out to the point where it is flowing all the time (not likely here).
As I stated in the post, the DTC may be false itself (DPFE). If so, then the DTC has nothing to do with your base complaint.
It could just be a smoke screen to your real problem. At the very least, the DTC would prevent your car from passing inspection.
I would be real surprised if changing the cats made the P1406 problem go away.
I am normally a test first and then replace kind of guy. For this problem, I have changed out more "good" parts in the interest of narrowing down the real cause. Can be frustrating.
Good luck.
PS, if the DTC code had been in the original post, I would have chimed in much sooner.
mirage86
78
#15
  • Oct 16, 2009
  • #15
Update
Got the o/r x pipe on and shes alive. Had a collapsed cat. As for the code, I'll figure it out later.
Pearl02
496
Kansas City
Oct 17, 2009
#16
  • Oct 17, 2009
  • #16
How did that happen? Pearl02.
mirage86
78
#17
  • Oct 19, 2009
  • #17
I have no idea. When I got the stock pipe off, I looked down the pipe on the drivers side and a piece of the element was laying over ****-eyed. 4000 miles earlier and I could have had it replaced under emissions warranty. Figures!
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
