no quad brackets?
  • Thread starter Thread starter ratrapp
  • Start date Start date Sep 23, 2004
R
ratrapp
510
buena vista,va
Sep 23, 2004
  • Sep 23, 2004
i am doing my turbo coupe rear swap and noticed that my old rear doesn't have any quad brackets on it and doesn't appear to have been cut off.it's an 8.8 rear but i'm wondering what the rear could have come out of because i'm probably going to give it to a friend of mine with a 7.5 because mine does have 3.73s,just no limited slip in it.
R
ratrapp
510
buena vista,va
Sep 24, 2004
  • Sep 24, 2004
ttt
trbkrb
1,976
Houston, TX
Sep 24, 2004
  • Sep 24, 2004
The Mark VII rear ends were the same basic 8.8 as the Mustangs, but no quads and for the most part, no limited slip.
R
ratrapp
510
buena vista,va
Sep 24, 2004
  • Sep 24, 2004
thanks,that may be what it is because the engine originally in the car when i got it was an 86 lincoln 5.0 so they may have swapped thr rear in it also.it does have drum brakes on it,did the markvll have drum brakes on the rear?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 24, 2004
  • Sep 24, 2004
Get a good set of upper and lower control arms and you won't need the quad shocks anyway.
Silentst2000
145
  • Sep 24, 2004
The quad shocks were a bandaid to the wheel hop problem. As said earilier, get a good setup and you won't need them.
trbkrb
1,976
Houston, TX
Sep 24, 2004
  • Sep 24, 2004
If it was a Mark VII rear, it originally had disc brakes. But the 7.5 and the 8.8 drum brakes are the exact same and would both bolt up to the Mark VII, Turbo Coupe and Mustang 8.8 rear ends with no problem. They probably just swapped the drums onto it.
R
ratrapp
510
buena vista,va
Sep 25, 2004
  • Sep 25, 2004
thanks guys,i already have a set of blueoval rear control arms on it.i'm not planning on hooking up the quads on my turbocoupe rear, i was just curious as what the rear could have come out of.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Sep 25, 2004
  • Sep 25, 2004
I think 4-banger cars didn't come with quads either
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
