  • 1994 - 1995 Specific Tech
no spark/injector pulsing
  • Thread starter Thread starter cbarr300
  • Start date Start date Mar 22, 2007
C
cbarr300
746
goose creek, SC
Mar 22, 2007
  • Mar 22, 2007
and it's not the PIP sensor.
I just recently dropped my engine back in and I'm 100% sure all the connectors are hooked back up like they should be.
I used a noid light to test for injector pulsing and they weren't pulsing. I changed out the distributor to a known good one and still no pulsing.
Can anyone point me in the right direction or tell me how to test the vehicles PIP harness?
also, I cut the wires for the fuel pump on the CCRM (ran a relay). I think it was the: Power to pump wire, input for pump (ground), power from battery, and switched 12 volt ones. Could any of those not being connected to the ccrm cause a no spark/no injector pulsing condition?
btw, I checked all the fuses but which ones should I check again just in case?
thanks
C
cbarr300
746
goose creek, SC
Mar 22, 2007
  • Mar 22, 2007
ttt
C
cbarr300
746
goose creek, SC
Mar 22, 2007
  • Mar 22, 2007
UPDATE: well, I borrowed an ICM from a friend and I'm going to put that on and see if that does anything
I still don't know why the fuel injectors aren't pulsing.
oh yeah, I tried to pull codes....and my code scanner wouldn't do anything.
C
cbarr300
746
goose creek, SC
Mar 22, 2007
  • Mar 22, 2007
OK sooo...another update:
after using the handy dandy search button and finding some VERY useful diagrams of the ccrm...I realized my dumb mistake.
basically, when I wired up my fuel pump relay I cut the wire that goes to 13. I thought it only connected to the FP relay....however, that one happens to control the pcm relay.....which controls injectors and all kinds of other stuff.
I'm 100% sure that's my problem...but I'm going to check it as soon as I can get to my car.
just putting it down in the forums in case anyone else has this problem.
This place is awesome
C
cbarr300
746
goose creek, SC
Mar 22, 2007
  • Mar 22, 2007
welp, it fixed a few things...but still having the no spark/no injector pulsing
stator is good
O
odiedog
210
Little Rock, Ar.
Mar 25, 2007
  • Mar 25, 2007
Man, I'd like to give you positive input on your problem, but you've already tried everything I ever have. Is there any possibility the new PIP was bad?
I do hope you get this thing solved... Its kinda like ready a :SNSign: version of days of our lives
good luck,
Odiedog
O
odiedog
210
Little Rock, Ar.
Mar 25, 2007
  • Mar 25, 2007
that was supposed to be reading a stangnet version of days of our lives.....
Guess my keyboard is a chevy....
HISSIN50
34
129
Mar 25, 2007
  • Mar 25, 2007
I talked to Clay about it a little bit and I believe he got it all fixored up already (he tore through and did quick diagnostics).
It was a wiring issue.
C
cbarr300
746
goose creek, SC
Mar 26, 2007
  • Mar 26, 2007
oh sorry, I meant to update this.
JT, part of my problem was pin #13 for the eec relay. I fixed that and my code reader finally started working (though it didn't throw any codes that really helped me), but I was still having the issues. Well, I was leaning against the connector for my fuel injector harness and I saw my noid light that was still hooked up starting to flash .....checked it and found that I didn't completely bolt it down (d'oh)
currently: Car cranks, runs, and backfires occasionally at idle (I have to get a grommet for my ACT sensor so theres a bit of un-metered air coming in... and I still haven't timed it because I got a bit lazy). My major problem right now is the snapped valve cover bolt and the EZ OUT that's snapped off in it....gotta take the car to a machine shop once I tune it up a bit with the tweecer.
Thanks to everyone that helped
This place is awesome....and btw, that search button works pretty well
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
