no spark issues :(
  • Thread starter Thread starter nine3cobra
  • Start date Start date Apr 11, 2011
nine3cobra
59
ft. walton beach FL
Apr 11, 2011
  • Apr 11, 2011
scenerio: i was driving and my ignition shut off almost as if the key was turned off and kicked back on after about 5 seconds with a huge backfire which blew my exhaust connections apart. it did this about 4 time before finally completely shutting off. i pulled over and it would crank but would not fire, and had no spark. however after running out of ideas i pulled the spout connector and it fired right up and runs fine so i drove to a buddy's house and changed out the distributor with a reman and a tfi module. but that did not fix it, in fact if the car is running and i go to plug in the spout it immediately shuts off. with the spout pulled there is no check engine light and there are no codes stored in the ecu according to my walmart eecv scan tool, also the stock tach is functioning if that means anything. i pulled the ecu and checked connections and shot the wires to the tfi to ground and each other. also i have checked my ignition switch and everything checks out there as well. i have poked around on here a bit and have read similar problems but i have run out of ideas as to what could be causing it
if anyone could toss out a couple of ideas/something i missed i would greatly appreciate it!
Rick 91GT
Mustang Master
95
99
PA
Apr 11, 2011
  • Apr 11, 2011
I believe if it will start with the SPOUT out, but die when plugged in and will not start with it plugged in you have a EEC failure/issue.
Did you check voltage at the Spout? Voltage should rise when the Spout is plugged in (as timing increases), if it doesn't then it is not working properly. Check each leg at the SPOUT connector, below 5v will cause you issues in most cases it will not idle or start.
Good Luck, I hate electrical issues......
If you have a chip in the computer pull it out.
nine3cobra
59
ft. walton beach FL
Apr 11, 2011
  • Apr 11, 2011
it had a chip in it at one point but it there is not one in there at the moment, how do i measure voltage at the spout? just pull it and run a volt meter inline and turn the distributor? i'll give it a try. can i put an a9l ecu in the cobra? i have heard you can do it and it will work (better) and i have also heard the pin out is different and they don't work. i am just asking because most part stores just see them all as the same and interchangeable between the a9l a9p and x3z so it may be hard finding an actual x3z. i have a dbx digital 97mm maf calibrated to 42lbs injectors so regardless of what ecu is in it i should be able to get it to work, i just don't want to complicate the issue any more than it is
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 12, 2011
  • Apr 12, 2011
The computer pinout is the same for all 89-93 5.0 Mustangs.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 16-Jan-2011 to clarify testing the EEC relay in paragraph 1E .
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
nine3cobra
59
ft. walton beach FL
Apr 12, 2011
  • Apr 12, 2011
i have seen that in another post on the issue and have exhausted it.
1) there is no spark
a. problem exists with msd connected and bypassed
b. replaced entire distributor with new reman unit (including new TFI module)
c. yes but only with the spout out
d. ruled out coil since engine runs perfect with spout pulled
e. 12vdc power at eec
f. fuse link good, plenty of fuel
g. 12v at ignition switch is good
h. eec ground is good
i. pulled ecu, checked connections/shot wires to tfi/dist
j. secondary ground there and good
k. does not even try to start with spout removed
the rest of the items on the list are good, i guess i will toss an ecu in there. the check engine light comes on in acc and extinguishes when started so i was thinking it was good according to what i have read in another post. also i noticed on the list that if my pip was bad my injectors would not fire, they are firing which tells me that it is working correctly in that aspect just failing in the other. what is changed within the ecu when the spout is pulled, does it use a different logic circuit within the ecu for the base 10 degree timing with it removed?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 12, 2011
  • Apr 12, 2011
Do you have 12 volts at the coil red/green wire?
PIP problems & diagnostic info
Spark with the SPOUT out, but not with the SPOUT in suggests a PIP problem. The PIP signal level needs to be above 6.5 volts to trigger the computer, but only needs to be 5.75 volts to trigger the TFI module. Hence with a weak PIP signal, you could get spark but no injector pulse. You will need an oscilloscope or graphing DVM to measure the output voltage since it is not a straight DC voltage.
See http://www.wellsmfgcorp.com/pdf/counterp_v8_i2_2004.pdf and http://www.wellsmfgcorp.com/pdf/counterp_v8_i3_2004.pdf for verification of this little detail from Wells, a manufacturer of TFI modules and ignition system products.
Rick 91GT
Mustang Master
95
99
PA
Apr 15, 2011
  • Apr 15, 2011
Any update??
nine3cobra
59
ft. walton beach FL
May 2, 2011
  • May 2, 2011
the latest:
after saving some money to continue throwing parts at the car, i bought a new motorcraft distributor with motorcraft pip and x3z ecu. i also picked up a borgwarner tfi. installed all the parts and the car started right up with spout installed. it started every time with every part so i don't know which one actually fixed it at this point. my timing light decided it was done working so did the advance the timing untill it hardstarts and bump it back a couple degrees so i could drive the car over to the base hobby shop. on the way there the car just died again after getting hot and would not start. pulled the spout and the car started and ran fine. so i am still trying to figure it out. if it wasn't for all the money i have dropped into it it would have been sold long ago.
all of the wiring is good, i have checked all ecu pins/connections, i have gone through all of the steps multiple times that jrichker posted and have replaced all of the most likely parts several times i am starting to think i have several problems/bad "new" parts and i just have awesome luck
blistovmhz
Active User
Mar 2, 2015
11
  • Mar 2, 2015
I created an account on Stangnet for the sole purpose of this post .
My roomie picked up a 90 foxbody gt from a body guy who we suspect could never get the car to run right. I've no idea what's all done to it other than gt40p heads, cam, chip, and an absolute up job on all the wiring. Car ran perfect when he picked it up, made heaps of power, but would occasionally die after driving a few minutes, then would start right back up after letting it sit for 15 minutes. I think we had a couple totally separate problems:
  1. Fuel tank anti-slosh baffle had broken free of it's stamp welds and was sliding around in the tank. This took out the fuel sending unit entirely, and was probably pulling the pump up sideways so it couldn't reach the fuel. He'd fill up the tank, drive for 20 minutes, and it'd die. We'd add 5L of fuel and we're off to the party again. - Replaced tank/pump/pickup.
  2. One of our dizzy's had a bad ignition module connector. - Swapped dizzy
  3. At least one or two of the ignition modules were bad. - Stole a few pockets full of ignition modules
  4. The entire engine harness was a mess. Found a few intermittent shorts, sensors run to the wrong wires all the way back to the ECU, etc. - Rebuilt the entire harness.
After all this, we were no longer throwing any codes, but were getting intermittent spark. Ran through all the standard "no spark" checklists and found that while we always had PIP at the ignition module, we weren't getting anything from SPOUT occasionally (I think).
We overlooked the answer for several days because we were expecting that the ECU would throw a code for anything we could think of. Specifically, we figured if the ECU wasn't receiving PIP (which we knew we had at the TFI), we'd get a code for it. Turns out we were wrong.
Finally had my roomie tap the ECU while I cranked it and it fired right up. Tap again and it dies. He gave up and went inside to cry for a while, but I kept looking into it. Start engine, twist ECU slowly, stall. Huzah!.
Took an hour or so of carefully messing with all the ECU connector pins to figure out which one was causing the problem. I was sure it was the ECU power because the fuel pump relay was still on when the engine stalled, but when we crank with a no start, we weren't getting fuel pressure (and of course the pump wasn't kicking on at that time). Twist the connector a bit and we'd get fuel pressure. This threw us way off.
So as far as I can tell, the ECU doesn't engage the fuel relay during cranking unless it receives PIP. If no PIP, you'd think you'd get a code, but we didn't. Finally traced the problem to the PIP wire at the ECU. Removed it, crimped it down, discovered the clip was broken, isolated the PIP wire from everything else so we could move it without disturbing anything else. Sure enough, engine fires right up and stalls on command.
We'll be hot-gluing the ECU connector together tonight until we find a new one to splice on.
But, so ya'll know, loss of PIP doesn't necessarily generate a code from the ECU. With PIP not making it to the ECU, you will not get fuel pressure during cranking. I for the life of me, can't figure out why there's no code. Hope this saves someone a week of headaches.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 3, 2015
#10
  • Mar 3, 2015
  • #10
More on the PIP problems that will drive you crazy trying to troubleshoot them...
Code 14 - Ignition pickup (PIP) was erratic – the Hall Effect sensor in the distributor is failing. Bad sensor, bad wiring, dirty contacts. Factory tach will sometimes read erratically.
Revised 10-Dec-2012 to add PIP diagnostic testing & Wells info
The PIP is a Hall Effect magnetic sensor that triggers the TFI and injectors. There is a shutter wheel alternately covers and uncovers a fixed magnet as it rotates. The change in the magnetic field triggers the sensor. They are often heat sensitive, increasing the failure rate as the temperature increases.
PIP Sensor functionality, testing and replacement:
The PIP is a Hall Effect magnetic sensor that triggers the TFI and injectors. There is a shutter wheel alternately covers and uncovers a fixed magnet as it rotates. The change in the magnetic field triggers the sensor. A failing PIP sensor will often set code 14 in the computer. They are often heat sensitive, increasing the failure rate as the temperature increases.
Some simple checks to do before replacing the PIP sensor or distributor:
You will need a Multimeter or DVM with good batteries: test or replace them before you get started.. You may also need some extra 16-18 gauge wire to extend the length of the meter’s test leads.
Visual check first: look for chaffed or damaged wiring and loose connector pins in the TFI harness connector.
Check the IDM wiring – dark green/yellow wire from the TFI module to pin 4 on the computer. There is a 22K Ohm resistor in the wiring between the TFI and the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 22,000 ohms +/- 10%.
Check the PIP wiring - dark blue from the TFI module to pin 56 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the SPOUT wiring – yellow/lt green from the TFI module to pin 36 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the black/orange wire from the TFI module to pin 16 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the red/green wire; it should have a steady 12-13 volts with the ignition switch on and the engine not running.
Check the red/blue wire; it should have a steady 12-13 volts with the ignition switch in Start and the engine not running. Watch out for the fan blades when you do this test, since the engine will be cranking.
If you do not find any chaffed or broken wires, high resistance connections or loose pins in the wiring harness, replace the PIP sensor or the distributor.
The PIP sensor is mounted in the bottom of the distributor under the shutter wheel. In stock Ford distributors, you have to press the gear off the distributor shaft to get access to it to replace it. Most guys just end up replacing the distributor with a reman unit for about $75 exchange
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
