no spin?
  • Thread starter Thread starter mikey5.0
  • Start date Start date Aug 11, 2006
M
mikey5.0
  • Aug 11, 2006
I know this is dumb to ask but, i took her out playing around on the back roads and i noticed that on take off in frist to 2nd i get lil bit not much spin now most stang guys would love this NO SPIN means better ET's yes but should my car be hooking this good on street tires, 3'73's and fairly stock susp i have SSM uppers and KYBs. I did however noticed that my factory bushings when i swaped rears where in great shape almost look new in all the control arms how is this ? it kinda worrys me i think i should be blowing the tires off from 1-2 NO TQ maybe its seems like the crappy stock conv is locking up way to soon or something?
HISSIN50
34
129
Aug 11, 2006
  • Aug 11, 2006
When most guys talk about roasting tires, it's with manuals.
F
foxstang9050
158
El Doarado Hills, CA
Aug 11, 2006
  • Aug 11, 2006
I had the same problem.... until i threw in a 2800 stall
M
mikey5.0
  • Aug 12, 2006
So is this bad or good ?form the way my car takes off i should have no problem reaching low 13's with crappy heads Got a feeling somthings wrong though.
bsedwebt70-5.0
320
Charlottesville, VA
Aug 12, 2006
  • Aug 12, 2006
if you have a mass aif flow meter you can clean the little heated wire elements inside it with electrical parts cleaner and gain quite a bit usually. Also you can unplug the spout connector on the distributer and bump the timing to about 14-15 degrees advanced and gain quite a bit - put the spout back in after setting the timing. Make sure your air filter is clean. etc... simple fixes will solve your problem - for next to no money - just time and learning will make you smile.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Aug 12, 2006
  • Aug 12, 2006
if its an automatic get a new stall, good traction is key to getting good times, yes, but on street tires and little mods not being able to spin the tires is a bad sign, honestly I dont think you could get under 15's, the stock crappy aod's will hold back any mustang.
And honestly bumping timing, cleaning maf, and a new air filter will not help in this situation.
ninety15.0
1,336
  • Aug 12, 2006
Dude that was one of the most difficult posts i have ever read. PUNCTUATE!! Anyways, I don't know of many AOD mustangs with stock stall conv. that blow the tires off while shifting?! Even with 3.73's! I would say its pefectly normal. What are all your mods?
N
NFGTragedy
155
Rochester, NY
Aug 12, 2006
  • Aug 12, 2006
I know my stock aod can rip up the tires up if I powerbrake it up a bit but as for just flooring it... not really as much but I also have 275's out back. I bought the transgo shiftkit and have hopes to pickup a decent stall converter which will hopefully liven it up a bit. If not it might be time for me to look at a t5 setup.
I know for sure my uncles 5spd with 2.73s can rip up the tires pretty easily... but then again if you can't break the tires loose with a 5spd then you should hand in your keys. I'd say if your looking at only breaking the tires loose then go with a higher gear (4.10+), a stall converter, possible shiftkit, and some cheap ass rear tires That would net the biggest "spin".
I know most people here would rather them hook then spin... but to each his own. Of course if you wish to just make it quicker then the stall / shiftkit would make the big difference... also powerbraking 1st and manually shifting from 1 to D at a higher rpm would cause both 1st and 2nd to spin / bark the tires.
M
mikey5.0
  • Aug 13, 2006
I have no crappy aod. heres my mods 83' capri 86block 306ci hyper pistons stock rods with ARP bolts comp roller timing chain FMS E303 cam RPM intake 600cfm edlebrock carb milled e6's bbk shortube headers no cats custom H pipe 2chamber flows dumped C5/C4 3.73 gears SSM uppers kyb's removed swaybar. Iam thinking its the convertor becuse when my brakes where better i use to could stall up to 1700-1900 rpms on the stock conv and it would do a lil but more of spin but, every since my brakes went south and i added 373's no spin only can stll up to 1000 -1200 rpms now.
I think i would sell this car if i ran 15's and i would be pissed if i ran slower then 14.5. I know its not much but should be high 13's with good driving and traction.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
D
1994 GT issues
  • DLB1985
  • Jul 2, 2022
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 2, 2022
General karthief
Engine Help diagnose random overheating??
  • TomOsiris
  • Apr 10, 2022
  • 5 6 7
17K
Fox 5.0 Mustang Tech Jul 3, 2023
General karthief
M
shocks/struts/inner tie rod, lower ball joints replacement, how to check, where/what to buy, etc.
  • mostsmooth
  • May 29, 2021
4K
1994 - 1995 Specific Tech Jun 5, 2021
95GTS2
9
